2011 fog lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 01-21-2011, 05:05 PM Thread Starter
2011 fog lights
Is the ps24w (the GM fog light bulb) the same as the psx24w? I can't seem to find the psx24w online so I might get the GM kind.
I also found out that the py24w is a yellow bulb that is used in BMW's for turn signals so that could be an option.
Cracker is offline
post #2 of 9 Old 01-24-2011, 01:10 PM
Panamon Creel's Avatar
The bulb itself is pretty much the same but the base is differently "coded" (PS24W --> PG20-3 Base, PSX24W --> PG20-7 Base) so it may not fit without modifications/removal of the coding tab(s).
Panamon Creel is offline
post #3 of 9 Old 01-29-2011, 09:10 AM Thread Starter
I just got the bulb in the mail and it is the exact same but with different coding tabs like you said. I just shaved them off and it works fine.
Cracker is offline
post #4 of 9 Old 02-05-2011, 02:05 AM
07unlimitedx's Avatar
I just found out that the H3 bulb should replace the factory PSX24W. Hope this helps someone.
Steve
07unlimitedx is offline
post #5 of 9 Old 02-05-2011, 10:40 AM
Hmmm lets see,
PSX24W
H3
Do you still think you can just simply replace it with a H3 Bulb?
post #6 of 9 Old 02-05-2011, 11:35 AM
Mechanic
2008fx4's Avatar
you can use a h16 bulb, but you have to cut off several tabs on the new bulb's plastic housing to get it to work
Jon R.
Owner, Bullpen Garage
18 E Ventura St
Tucson, AZ 85705
520-396-3001
2008fx4 is offline
post #7 of 9 Old 02-05-2011, 10:45 PM
Hmmm lets see,
PSX24W
NOPE... There must have been some work to get it to work... Not sure.
post #8 of 9 Old 02-09-2011, 07:22 AM
Yeah might be but I doubt that the filament position within the reflector will be the same thus it may create an "out of focus" condition which, if the fog light is actually used for its purpose in foggy condition, can cause unwanted reflections back to the driver thus having a detrimental effect on visibility.
post #9 of 9 Old 02-09-2011, 09:49 AM
Mechanic
2008fx4's Avatar
the filament is pretty much in the exact same position. the lighting spread and output with the yellow nokya h16 bulbs i put in was exactly the same as the stock bulbs, only a different color. you can always adjust the fogs too.
Jon R.
18 E Ventura St
Tucson, AZ 85705
520-396-3001
2008fx4 is offline
