Air Bag Light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-08-2011, 02:58 PM Thread Starter
Air Bag Light
My Air Bag light keeps flashing and dinging every 30seconds or so. Anyone had this issue before? Oh yea. Its a 07 Rubi Unlim
DLEII is offline
post #2 of 6 Old 01-08-2011, 03:16 PM
SONIC's Avatar
I have mine constantly on. I need to figure it out as well.
No dinging here though
-Doc Holiday
SONIC is offline
post #3 of 6 Old 01-08-2011, 03:34 PM
Cbass122's Avatar
Did you use any type of programming device on you rig to change tire size or gear ratio?
I had a problem a while ago where my airbag light went off. I took it to the dealer and they said some control module lost the association w/ the VIN number??? I don't know the details exactly but the dealer took care of it while I was in taking care of some other work.
Cbass122 is offline
post #4 of 6 Old 01-08-2011, 03:44 PM
HOOLIGAN's Avatar
Clockspring?
HOOLIGAN is offline
post #5 of 6 Old 01-08-2011, 04:44 PM Thread Starter
Im leaning toward the contact issue...which is usally the clockspring (as per some other posts i googled). It is not staying lit....and it is not flashing/dinging at regular intervals. Seems like when i am offroad (just took to my farm to test out the locks and sway bar disconnect) and it goes on and off like crazy....when i got back on the road in 2wd it definatly went off and dinged much less.
Is this a DONNIE-CAN-FIX-IT issue if it is the Clockspring issue? Or maybe a warranty/dealer issue? Or more of a $250ish dealer clear some code issue?
Thanks for the input!!!
DLEII is offline
post #6 of 6 Old 01-11-2011, 07:16 PM
Cbass122's Avatar
If it is new and still under warranty you are probably good to take into the dealer. My JK had 5k miles on it and was covered no charge. They took care of it. Even though I think it may have been my fault, I did not tell them that or anything surronding the incident
Cbass122 is offline
