HELP!!!! Hella lights won't stay on - JKowners.com : Jeep Wrangler JK Forum
post #1 of 39 Old 01-06-2011, 01:03 PM Thread Starter
HELP!!!! Hella headlights won't stay on
I purchased the Hella headlight upgrade from Rally lights. I hooked them up no problem. On my way to work next morning they cut out on me. I called Susquahanna motor sports and they sent me a new harness. Ray, the guy who builds them told me it probably was not the harness but would send me another one any way. Great customer service.
Well I got the new harness today and installed it. Before I buttoned everything back up I cranked the Jeep and turned the lights on. Well, what do you know, the damn things cut off on me again.
Does any one know what could be causing this. The harness is connected to the battery and the trigger is the passanger side head light. I know it is hooked up correctly..any ideas would be greatly appreciated.....
07 2 Dr White Rubi, 6spd
Linexed tub
EVO Rear Bumper Fascia
Poison Spyder Boby Mounted Tire Carrier
Matercraft grab handles
M.O.R.E. 1" BL
Shrockworks midwidth w/ winch hoop / Linexed
Warn 9.5TI / Spidertrax fairlead / Viking trail line
Marathon Seat covers
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
3.5" Rock Krawler X Factor
Coil Overs Front/rear
12" rear stretch
River Raider stretch corners
Smittybilt XRC front enders
07JKRUBI is offline
post #2 of 39 Old 01-06-2011, 03:53 PM
HOOLIGAN's Avatar
My guess is the CANBUS system doesn't like your set up and it's shutting it down. Can you add a relay to it?
HOOLIGAN is offline
post #3 of 39 Old 01-06-2011, 04:08 PM Thread Starter
This is the kit with the relays....That's what has me so frustrated..I can plug my old lights in and they work fine but for some reason when I plug in the harness I can't keep power to the relays....
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #4 of 39 Old 01-06-2011, 04:39 PM
I would use a volt meter to double check you are getting power to the relays from the battery then check to see if you are getting power to your relays from your stock light plugs back to the relays. See what the point of failure actually is.
-Mallow
Mallow is offline
post #5 of 39 Old 01-06-2011, 05:11 PM
Joneszj's Avatar
And I know you stated that its installed correctly and maybe this is a dumb question that you've already checked, but could it be an improper ground?
I recently installed a set of KC HiLites and struggled to get a good ground. Even once I had it set up at one point, it would cut out occasionally until I found a better bolt to ground it to. And is the switch grounded correctly also? Just figured it might be worth checking. If its not that it may still be the whole canbus thing that I know nothing about.
1972 Commando on Tons & 40s
Joneszj is offline
post #6 of 39 Old 01-06-2011, 05:13 PM
The kits ground wire connects to the negative terminal of the battery as long as he followed the directions.
Mallow is offline
post #7 of 39 Old 01-06-2011, 05:20 PM
Slow and Low
Co4Lo's Avatar
Trigger your relay with the marker light 12v+ lead and see what happens. The marker light lead is not a pulsed circuit like the headlight.
I had to trigger my HID's off the markers because they would flicker and shut off when using the pulsed circuit.
Might work for your application also.
Co4Lo is offline
post #8 of 39 Old 01-06-2011, 05:42 PM
07unlimitedx's Avatar
I would say it's the pulse the canbus system puts out that is shutting off your relay.
07unlimitedx is offline
post #9 of 39 Old 01-06-2011, 05:59 PM
The Rallylight harness has the resistors in line that should eliminate the pulsing and fools the canbus into thinking everything is fine. Mine was definitely plug and play in my 2010 Rubicon.
Mallow is offline
post #10 of 39 Old 01-06-2011, 06:16 PM Thread Starter
I do have it grounded to the battery so I don't think that is the problem. My question is, what could be causing the power from the head light switch to cut power to the relays. It's as if the canbus sees the upgraded light bulbs.
I thought that maybe the harness had faulty resistors but when the second harness offered the same results it kind of rules that out. There has to be something telling the canbus to kill the power to the harness, but what.
If I plugged my old bulbs in and they wouldn't work then I would know I had an electrical issue with the Jeeps wiring, but like I said, they work fine. I can only keep the Rallylight harness operating for about 2 minutes before it cuts out, doesn't make any sence...
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #11 of 39 Old 01-06-2011, 06:24 PM
Could it be due to a power drop? I know they can pull alot more watts than the current light bulbs. Maybe the jeep is shutting off lights/accessories due to the voltage of the battery getting to low? I am not sure if the jeep has this feature or not but some vehicles do.
Mallow is offline
post #12 of 39 Old 01-06-2011, 06:39 PM
Slow and Low
Co4Lo's Avatar
Like I said... just try using the marker light as a trigger for the relays and see if it works. Simple way to determine if the pulsed CANBUS circuit is fawking up your show.
Co4Lo is offline
post #13 of 39 Old 01-06-2011, 07:09 PM
I would put an ammeter on the trigger signal and see how much current you're drawing... for some reason the CanBus thinks the current is too high and is turning off the circuit.
Might also try routing the trigger wire to the driver's side and see if that works any better...
J_Westy is offline
post #14 of 39 Old 01-07-2011, 10:23 AM
I don't have anything to offer in regards to your problem, but I have that exact setup on my 2007 and it works great. I don't think there is a problem with the CanBus system and the Rallylights setup. Mine was plug and play.
Sorry I can't be of more help, and good luck.
2007 JK Rubi Unlimited - 5" Teraflex, 37" Iroks
2005 LJ - HP60, 14 Bolt, 39.5, some other stuff
1978 J10 SOA and 35's
WahooJeep is offline
post #15 of 39 Old 01-07-2011, 10:32 AM
I have some experience with control circuits and supervisory circuits. So I think that the canbuss is the problem. You will have to find a way to trick it ( I thought that someone sells a device to do this). You mentioned that you are only using one wire out of the headlight circuit. Some supervisory circuits must see a return. We alread know that the control circuit is looking at the load. Most people discover this when they increase the load. Maybe to small of a load will cause a fault. Also an unballanced load could cause a fault. If you could read the fault. You would then have a better chance ofresolving the issue.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #16 of 39 Old 01-07-2011, 12:19 PM Thread Starter
OK, I have on the phone with Ray on and off all day, we have tried several things and nothing is working.
I checked all my grounds and they all check out. I took voltage readings with my stock lights and with my harness and all readings are 11.2v withe factory lights and 13.6v with the harness side. After the lights have been on a while the voltage drops to 2.1 and pretty much stays there. For the stock lights no problem, but for the harness this is the voltage that causes it to go out.
The relays engage at 8.5v and disengage at a voltage less than 2. I know 2.1 is close but it is still greater than 2. At this point, after having the Jeep apart the last 2 days, I am left with putting my crappy stockers back in
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #17 of 39 Old 01-07-2011, 01:21 PM
Slow and Low
Co4Lo's Avatar
So...
why not just trigger the relays with the marker light circuit?
Co4Lo is offline
post #18 of 39 Old 01-07-2011, 01:30 PM Thread Starter
I might have to, but as a last resort. I just hate that I spent all this money on a plug and play harness that no one else has problems with and I can't get it work with my Jeep. I am just trying to figure out what is different in my Jeep then everyone elses.
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #19 of 39 Old 01-07-2011, 01:35 PM
Slow and Low
Co4Lo's Avatar
If it makes you feel any better, my Jeep randomly does a lot of stupid shit. For example, my switched dimmer wire for my stereo has turned itself into a constant 12v after 3 years of having the same stereo installed.
My lights have refused to turn on in the past, and sometimes I get a delay before they turn on.
And the best one of all... my Jeep has recently decided to not run anymore.
Co4Lo is offline
post #20 of 39 Old 01-12-2011, 07:28 AM
Hilldweller's Avatar
I sent a link to this thread to DS; maybe he can figure it out.
I'm thinking different relays.
Did you try the cheap bulbs?
Safety fast,
Get to know
Hilldweller is offline
post #21 of 39 Old 01-12-2011, 08:45 AM Thread Starter
I hope he can come up with something. I hate not being able to get them to work. No, I have not tried the cheap bulbs yet, the weather here the last few days has not been too good. I may try and get out there today and try the cheap bulbs and report back....
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #22 of 39 Old 01-12-2011, 10:57 AM
The "Power Logic Controler" in the jeep doesn't use relays on some things. It uses an electronic switch ( It doesn't have real contacts that open and close ). These switches leak by some voltage sometime. But the leek doesn't realy matter as long as it doesn't leak enough to make the circuit work. Bottom line - on a 12 volt system, 2.1 volts might as well be "0".
"The Green Monster"
on
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #23 of 39 Old 01-13-2011, 04:56 PM
Not sure why the bulbs would make a difference since they're on the other side of the relay...
I don't know if the left and right circuits are driven separately or not, but
1) If they're driven together, maybe the old driver's side connector is not just dangling but partially touching ground pulling more current than the CanBus wants to see.
2) If they're driven separately, have you tried triggering off the driver's side like I wrote above? There should be enough wire to route the trigger wire along the firewall and to the left headlamp.
3) Have you tried the high beams vs the low beams? I wonder if the high beams stay on correctly... which might point you to a bad relay, bad ground, partial short etc... upon which you could swap low-beam and high-beam relays and see what happens.
J_Westy is offline
post #24 of 39 Old 01-14-2011, 07:07 AM Thread Starter
I tried lower rated bulbs and to no avail. I get the same result with low and high beam, works a couple of minutes, clicks off and on a couple of times them goes out and stays out.
I am having another harness made and am going to bypass the computer all together. I am going to use a toggle switch to control the head lights. I am going to use a 12v switched source for the toggle so the lights will automatically go off when I turn off the ignition.
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #25 of 39 Old 01-14-2011, 04:07 PM
You did try swapping the trigger to the driver's side you said and also tried with the trigger on the passenger side and an H13 in the OE socket on the driver's side?
Check and check.
Did you swap the relays to see if the problem followed the relay? A bad relay was always my guess but I can't really conceive of getting two in a row and having them both be the high beam...
It really should work ----- I mean, it works for everyone else. It's a royal bummer; sorry, dude.
Safety fast,
Get to know
