Code p0058 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 01-06-2011, 06:07 AM Thread Starter
jeepdork's Avatar
Code p0058
From the looks of things it seems to be a bad O2 sensor? does that make sense to everyone here? MIL came on code was P0058 =O2 SENSOR 2/2 HEATER CIRCUIT HIGH, which one is it?
jeepdork is offline
post #2 of 11 Old 01-06-2011, 06:13 AM
Grant211's Avatar
just curious, are you running superchips?
Grant211 is offline
post #3 of 11 Old 01-06-2011, 07:23 AM Thread Starter
jeepdork's Avatar
nope no engine mods 45k first problem
jeepdork is offline
post #4 of 11 Old 01-06-2011, 07:58 AM
jacktuttle's Avatar
Lightbulb Smog
I think all Smog issues are covered by law for higher than the rest of the jeep. Check with your dealer.
jacktuttle is offline
post #5 of 11 Old 01-06-2011, 09:18 AM Thread Starter
jeepdork's Avatar
higher than the rest of your jeep??? what do you mean?
jeepdork is offline
post #6 of 11 Old 01-06-2011, 10:28 AM
ronjenx's Avatar
O2 sensor 2/2 is the lower one, on the driver's side, (left side of the vehicle).
The Emission Warranty is based on too many factors to list here. You can download the warranty book for your year JK from the Jeep web site.
P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH
When Monitored:
Continuously during O2 heater operation with battery voltage between 10.4 and 15.75 volts.
Set Condition:
The PCM detects that the O2 sensor heater element input is above the maximum acceptable voltage. One trip fault. Three good trips to turn off the MIL.
Possible Causes
O2 2/2 HEATER CONTROL CIRCUIT OPEN
O2 2/2 HEATER GROUND CIRCUIT OPEN
O2 2/2 HEATER CONTROL CIRCUIT SHORTED TO VOLTAGE
2/2 O2 SENSOR
POWER TRAIN CONTROL MODULE (PCM)
ronjenx is offline
post #7 of 11 Old 01-06-2011, 01:54 PM Thread Starter
jeepdork's Avatar
Got it, longer than the 3yr/36k thanks
jeepdork is offline
post #8 of 11 Old 01-06-2011, 05:33 PM Thread Starter
jeepdork's Avatar
Spoke to the dealer and O2 sensors are NOT covered under this deal. They want $385 to replace it. That sounds like WAYYYY to much. Am I off here or is that crazy? Could it be anything else?
jeepdork is offline
post #9 of 11 Old 01-06-2011, 05:51 PM
the o2 sensors are cheap, under 60 bucks at a autoparts store. You need a o2 socket, a ratchet. Thats it, unplug, unscrew, replace. Be prepare to do alot of yelling at the plug. Especially if you have been off roading and it got caked in mud and wouldn't budge......wait that might be just me.
jeepinjk is offline
post #10 of 11 Old 01-06-2011, 07:20 PM
ronjenx's Avatar
Have you eliminated a wiring or connector problem?
Three out of the five possible causes in post #6 are circuit related.
ronjenx is offline
post #11 of 11 Old 01-13-2011, 10:55 PM Thread Starter
jeepdork's Avatar
Thanks for all the help, I remembered that I have an extended warranty. easy care stated care, Called them today and it should all be covered for the $100 I have to pay to take it in. I'll post what it was when they figure it out. Thanks
jeepdork is offline
