Got a CB Radio. What Else Do I Need To Make It Happen? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 01-03-2011, 07:11 PM Thread Starter
allibaster's Avatar
I was fortunate enough to get a Cobra 75WXST CB radio as a gift for Christmas. I know I need to get an antenna, antenna bracket, and cable.
What else is needed?
Where's the easiest place to get +12V without having to go through the firewall?
Do I need to get any tools to terminate the cable to the appropriate connectors, or can I get them pre-terminated?
Anything else?
'13 JKU 10th Anniversary
allibaster is offline
post #2 of 8 Old 01-03-2011, 07:40 PM
I use the passenger side 12v plug in the dash to power my radio. It's on all the time (remember to turn the radio off), and a CB pulls pretty low current.
The coax (cable) has ends already on it, buy 18'. It is the best length to use in an automotive setting (according to people that know a lot more than I do about CBs and wavelengths). Do not coil any excess. kinda loop it around loosely under a seat/carpet/etc.
You'll need an antenna, probably fiberglass, and a mount.
It would be wise to buy or borrow a SWR meter to set/check the SWR. Too high can easily hurt a radio and have poor performance.
post #3 of 8 Old 01-04-2011, 12:05 AM
Could you please expand on this?
2012 Silver JKU Rubicon
5 speed auto, 4.10s
Riptide is offline
post #4 of 8 Old 01-04-2011, 05:04 AM
It's said that rolling excess coax will not allow it to perform correctly. I saw this on several "CB" sites before installing mine. It was either hard on it, or you would get interference, I don't remember which.
post #5 of 8 Old 01-04-2011, 05:21 AM
Loki646's Avatar
Depending on where you intend to mount the CB, going through the firewall really isn't that difficult and you can wire directly to the battery. When I get on the laptop later I'll link you to my switch install to show where a good spot to pass through the firewall without and drilling is. The other big thing is a good ground for both the radio and the antenna.
EDIT WITH LINK:https://www.jkowners.com/forum/showth...light=arc+8000
Loki646 is offline
post #6 of 8 Old 01-04-2011, 04:20 PM
Loki646's Avatar
I updated my write-up with an extensive 3 post read from Signalengineers.com. Hopefully it will give you a better understanding. It is a pretty lengthy read, but very informative.
Loki646 is offline
post #7 of 8 Old 01-04-2011, 04:29 PM
With the coax cable, just kinda make some lazy "S" shapes under the carpet. I have an unlimited, and ran the cable from the dash to the tailgate on the passenger side. I made lazy "S" shapes under the carpet under the back seat, and have had no issues with my radio. Get a decent mount (I've got the Teraflex, no need to run a ground wire), and decent cable, and you should be good to go.
08 Unlimited Steel Blue
All Sorts of Crap on it
In the space of about 30 seconds, this man was in a car accident, an explosion, lit aflame and then kicked in the balls with more force than a human foot can technically take.
Future terrorists take note: this is your retirement package.
lockednloaded is offline
post #8 of 8 Old 01-04-2011, 06:31 PM Thread Starter
allibaster's Avatar
Thanks guys!
