Atlas II, need to make it think its in 4wd... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 01-01-2011, 01:16 PM Thread Starter
Ok I am wanting to wire it up so that I can flip a swich to make the jeep think its in low range. I figure there is a way to do this with the stock shift indicator from the rock-trac. But I was hoping some of you may know how to do this. I was thinking that I could just splice into the pig-tail somewhere with a toggle and it would trick the jeep, allowing the lockers and sway-bars to work.
Any thought?
Action Fab is offline
post #2 of 8 Old 01-01-2011, 01:32 PM
I believe people take the stock sensor/connector off the stock transfer case and just run it into the dash. But I may be wrong on that
post #3 of 8 Old 01-01-2011, 01:33 PM
Hammered's Avatar
Any thought?
Why don't you just wire each locker and and the sway bar to there own switches so that you can use each one separately at any time? The only problem is the lights will still blink indicating they are not locked, but they will be.
Hammered is offline
post #4 of 8 Old 01-01-2011, 01:34 PM
There is a different throttle response map when in 4-low that may be useful
post #5 of 8 Old 01-01-2011, 01:48 PM
Hammered's Avatar
Isn't the different throttle response toned down in low range? These motors weak enough the last thing I would want is a slower throttle response in high range.
Hammered is offline
post #6 of 8 Old 01-01-2011, 01:50 PM
Right that is what happens. But if he never tells the JK it's in 4-low it will keep the stock throttle response/mapping. Which is why I believe most keep the sensor/connector for the stock case and just switch it like an ignition switch into low.
Someone that has done it will chime in I'm sure
post #7 of 8 Old 01-01-2011, 02:06 PM Thread Starter
Because the customer I am building the jeep for doesn't want blinking lights, Doesn't need front digs. He also wants the factory buttons to still work. What I am trying to do is allow him to push a "4wd" button and every thing work like it did from the factory.
post #8 of 8 Old 01-02-2011, 07:09 AM
JKDoc's Avatar
Any thought?
There is a write up on the Atlas page showing how to make the jumper. This requires two 60 Ohm resisters in series and a 100 ohm resister to jump across the wires. The 100 ohm resister is not needed in the 2007 but is needed in later years. Instead of attaching this to the switch provided with the switch kit for the Atlas, simply wire it to an on/off switch and mount on your dash. You pull the wiring up along with the shift cables into the center console. You can mount you on/off switch on the console or dash. I have mine mounted on the left side of the dash along with an emergency vacuum pump to activate my brakes if my engine dies. (The system is part of our tow package for our motorhome.)
This will light up the 4WD light on your dash. According to Advance Adapters this is all that is required. I've been running this for two years without problems. When the switch is activated, the gas pedal sensitivity is changed and the ESP is disabled. The ABS continues to work.
"Old age and treachery will overcome youth and skill", Bob Arnett
JKDoc is offline
