Hard to find switch! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 12-28-2010, 10:29 AM Thread Starter
Looking for a 30+ amp switch, toggle, lighted.
Here is the catch:
I want it lit when OFF, not on.
Can't seem to find one, my google-fu is weak today.
Basically this one, but set to light up while off, and 30+ amps.
Fnord5 is offline
post #2 of 13 Old 12-28-2010, 12:33 PM
tjkoen01's Avatar
does the light have to be off when the switch is "on"? if the light can stay on all the time, you can hook the battery to the load side and load to the battery side, that way the battery will be on the side that powers the light.
if you want the light to turn off, you could use a relay with a normally closed contact so that when the switch is on, it turns the relay on and thus opens the contact. run the ground thru those contacts and it will turn the light off when the switch is on
2008 Rubicon
Rugged Ridge XHD Bumper w/Warn XD9000i
315/70/17 Cooper ST Maxx, No Lift
Superchips Flashpaq
Flow Daddy Headers
Gibson Dual Exhaust
tjkoen01 is offline
post #3 of 13 Old 12-28-2010, 01:59 PM
jacktuttle's Avatar
Question confused
Here is the catch:
what are you doing with it?
jacktuttle is offline
post #4 of 13 Old 12-28-2010, 03:42 PM Thread Starter
I want it for my new Lightforce 170's I want it lit when off, so it is easy to find in the dark!
Actually, I could probably wire it up to stay on, constant... hmnnn
Fnord5 is offline
post #5 of 13 Old 12-28-2010, 07:13 PM
axsys's Avatar
I would suggest running a relay for the lights that you could mount in the engine. That way you can run a smaller gauge wire to your switch and not have to worry about running 30amps through your interior.
Plus, then you can find a switch that has an independent terminal for the indicator that doesn't need to support a 30amp current. For example, you can order a Contura switch that has an independent light for the top half, and then an indicator light for the bottom half once you flip the switch on. OTRATTW.com sells them.
axsys is offline
post #6 of 13 Old 12-29-2010, 02:49 AM
WeGo4x4's Avatar
Exactly. Run a relay if possible and make your life easier.
WeGo4x4 is offline
post #7 of 13 Old 12-29-2010, 06:57 AM
maverick's Avatar
Yes, run a relay... you don't want to run 30A unnecessarily up through your dash... safety issue AND unwanted voltage drop to your lights... one of the main reasons to run a relay in the first place.
maverick is offline
post #8 of 13 Old 12-29-2010, 07:59 AM Thread Starter
I have the Lightforce wiring harness, with relay ect...
The switch that came with the harness is a 30A rocker, I just want to keep the amperage rating the same, but swap the switch with one I want.
I guess that I could run a on/on switch with a separate light, so as ~ turn the 170's on, the indicator goes off, and visa versa.
Would solve most of the issues.
Fnord5 is offline
post #9 of 13 Old 12-29-2010, 10:57 AM
maverick's Avatar
Suggest you find out what relay it is to determine what contacts are available. Maybe you could simply power your switch from that relay.
Better yet, maybe power your siwitch from you parking, driving, or dash lights. Assume you typically will power the LightForces in conjunction with those light(s).
maverick is offline
post #10 of 13 Old 12-29-2010, 11:29 AM
maverick's Avatar
Google is your friend...
Maybe not the ideal answer, but... spend some time on Google...
First impression is this switch is illuminated either red or green dependent on on/off... Not sure if bright enought to show through cover.
http://www.radioshack.com/product/in...54#tabsetBasic
Seems only to be illuminates when on...
http://cgi.ebay.com/ebaymotors/RED-L...mZ230557036225
Your cover...
http://cgi.ebay.com/4-RED-TOGGLE-SWI...76192461442577
maverick is offline
post #11 of 13 Old 12-29-2010, 12:04 PM
chromedome's Avatar
Once you install it, it should stay put and not run around the inside of the jeep. If you just reach to the same location it should be there! Kinda like pissing in the dark.
chromedome is offline
post #12 of 13 Old 12-29-2010, 02:22 PM
I never had any trouble finding mine in the dark! Sounds like we need more interrior lighting mods.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #13 of 13 Old 12-30-2010, 07:00 AM Thread Starter
It's been all installed, working perfectly, but I want a different switch.
Fnord5 is offline
