Hella Supertone Horns - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 12-26-2010, 01:29 PM Thread Starter
BigMike's Avatar
I got a set for Christmas. Does anyone have pictures of where they mounted them?
, Granite,
BigMike is offline
post #2 of 16 Old 12-26-2010, 03:29 PM
hmmmm interesting horns once you get them in share how much louder they are then stock please. might be a good upgrade withought the trumpets
mattymat04 is offline
post #3 of 16 Old 12-26-2010, 03:31 PM
nlgrav182's Avatar
In front of the radiator would probably be a good spot. Lots of drillable metal to install them on.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #4 of 16 Old 12-27-2010, 12:57 PM
I don't have any pics, and it is currently a blizzard out, but I put mine in front of the radiator. I bolted them to the top crossmember between the grill and the radiator, there are holes there that you can use that hold the light wire harness I believe. I can try to take a picture through the grill when the weather dies down if you want, just not sure you are going to see anything.
Jollydodger is offline
post #5 of 16 Old 12-27-2010, 02:20 PM
LS6TT's Avatar
Send a message via AIM to LS6TT
http://jk-forum.com/showthread.php?1...erton-Horn-Set
make sure to post the before and after please, cant seem to decide on whatr horn to go with
-Alex
2010 2dr Sport | 2.5" BB Lift with 4dr Springs | More to come
LS6TT is offline
post #6 of 16 Old 12-27-2010, 04:11 PM
HOOLIGAN's Avatar
For those of us that have been banned, what's the link?
HOOLIGAN is offline
post #7 of 16 Old 12-27-2010, 05:50 PM
LS6TT's Avatar
oh sorry, its the install instructions for the horns.
-Alex
LS6TT is offline
post #8 of 16 Old 12-28-2010, 09:27 AM
chromedome's Avatar
Here you go, good luck with the install..........
chromedome is offline
post #9 of 16 Old 01-07-2011, 05:30 PM
numb_crna's Avatar
BigMike-
I put in a set of PIAA horns soon after I brought my 2010 Rubi home because the Mopar horn was no way up to the same level as the factory horn in my 2003 Chevy Tahoe family sedan / plow truck. . .
I soldered a Y lead onto the factory positive and ran it to the front grill. I fashioned a mounting bracket from a piece of aluminum flat stock. Since I used aluminum, I also ran a grounding Y.
The PIAA horns are loud and effective!
Good luck with your mod!
numb_crna is offline
post #10 of 16 Old 01-09-2011, 09:27 AM
l_jeepo's Avatar
I installed my PIAA horns by removing the factory Grill and drilling a set of holes to the inside of each headlight and mounted them. I just tapped into the horn wires and extended them to the PIAA lights. Very easy installation. Huge improvement.
08 JKU Ruby
WAY BETTER THAN STOCK!
l_jeepo is offline
post #11 of 16 Old 01-09-2011, 11:59 AM
HOOLIGAN's Avatar
Anybody able to post a sound clip or video so we can hear these horns?
HOOLIGAN is offline
post #12 of 16 Old 01-14-2011, 07:00 PM
numb_crna's Avatar
Very clean install. Nice!
post #13 of 16 Old 01-14-2011, 08:49 PM
fishgutz's Avatar
I want to put one on my Buell. The horn is so weak.
fishgutz is offline
post #14 of 16 Old 01-14-2011, 09:26 PM
07unlimitedx's Avatar
I've got to get me some of those... factory horn sucks
07unlimitedx is offline
post #15 of 16 Old 08-21-2011, 05:19 PM
Jeep2.0's Avatar
Old Thread
Seems like most folks here are wiring these straight in without a relay. Is that true? Any issues with a 2nd horn vs just one?
2011 5.3L GM LC9 Aluminum LS V8 Conversion w/ Custom Dyno Tune
Aluminum Genright Bumpers Front & Rear - Aluminum Nemesis Rockers
PR44/RCV/Reid Front - Superior Rear - ORF Front / Poly Rear Cage - ORF Tire Carrier
RK 3.5" Springs - Fox 2.0 Adjustable Shocks - JKS Arms & Trackbars - Poly Steering
Jeep2.0 is offline
post #16 of 16 Old 08-21-2011, 07:22 PM
I used a relay, stock wiring is too thin for me. Takes an extra 15 minutes maybe.
