Did i just.... - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 12-19-2010, 09:49 PM Thread Starter
Did i just....
Well i think messed up the superchips settings on my jk today.... my 3 year old battery finally died and i didnt return it to stock when it died. And when i put the new battery back in my jeep feels different...... did i just screw it all up? or can i just return it back to stock and reload it?????
JK ready for the build but the pockets aint
jchmelo is offline
post #2 of 3 Old 12-19-2010, 10:31 PM
nlgrav182's Avatar
Well, it would be the same as if you were to disconnect the battery to install something and left it unhooked for an hour or so. No difference to a Jeep; no power is no power. Once the PCM loses its power and all its backup power, it will shut off and default to either its stock tune or the last known tune, which would be Superchipped.
Plug the tuner in and see if you have anything installed. That would be the best way. Then, you can return everything to stock with the Original Stock Build that's saved in the Paq and then reinstall all your tuning.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #3 of 3 Old 12-19-2010, 10:49 PM
chevyjeep's Avatar
It should not have lost the setting. It does have to relearn were the best settings are for the way that you drive and adjust for that.
2007 Jk Rubicon
1952 M38A1
chevyjeep is offline
