Accessory Power w/ 410 Inverter problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 12-13-2010, 07:55 AM Thread Starter
I'm trying to power about 160w of Christmas lights on the jeep. I picked up a 410w Schumacher Inverter which has the accessory outlet plug + battery clamps. I connected it through the outlet, it turned on, plugged in lights, and they powered for a few seconds and then went off. Now, the inverter does not power (at all) through the outlet. It does power up when ran to the battery.
I tried the inverter w/ outlet hookup in my other vehicle and it doesn't power either.
Do you think this problem has to do with Amps/Watts through the jeep outlet? Or could it be a inverter acc outlet plug that is the problem?
Am I better off just running power from the battery into the cab to power the inverter?
JK-Carolina is offline
post #2 of 6 Old 12-13-2010, 08:02 AM
Did you check if there is a fuse built into the end of the cig lighter plug ON the inverter side? (male). Cap may unscrew to reveal one.
I bet you overloaded it, it probably states don't run "x" amount through it, thats why the battery cables are there I bet.
post #3 of 6 Old 12-13-2010, 08:58 AM Thread Starter
You are probably right. I will check for a fuse during lunch. The printed manual doesn't show a max load, but I found 120w listed in the online manual for the inverter through acc port.
What is the max load in a 2010 JKUnl accessory port? 300?
I might just pick up a larger fuse if that is the issue. They state 120w "to accomodate for use in most vehicles" and that some vehicles may handle the max wattage of the inverter.
post #4 of 6 Old 12-13-2010, 09:11 AM Thread Starter
Update - I've thought about the larger fuse option and to avoid a possible electrical fire....I'll likely just hardwire to the battery and mount it under the rear seat. :-)
post #5 of 6 Old 12-13-2010, 10:13 AM
Larger fuse is a bad idea. And will also probably blow the fuse in the Jk as well. I think the stock load is 20a. You would need to convert watts to amps running at 12v to get the max.
Really should just run it to the battery as it's designed...either hard wire it or just use the clamps and run the wiring into the door seal for the temporary time the lights are on.
post #6 of 6 Old 12-14-2010, 05:03 AM
The cig lighter circuit is 20 amp max
20A * 12V = 240 watts
The inverter is to big for the cig lighter circuit.
410 watts / 12V = 34.16A
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
