Injectors Impedance - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 12-06-2010, 04:19 PM Thread Starter
Injectors Impedance
Does anybody know the answer? I need to know as part of the MODS. Am going for 50 LPH Thanks all
offroadpr is offline
post #2 of 15 Old 12-08-2010, 11:24 AM
FuLcRuM's Avatar
Almost all OEM injectors are High Impedance. I can't say for sure they are in the JK but I would assume they are.
You can test them using a multimeter if you have one.
Low Impedance injectors are characterized as peak and hold types. They will have a winding resistance from 1.7 to 4.7 ohms.
Injectors with impedances from 10 to 16.5 ohms (high) do not require the external resistors.
snippets taken from www.sdsefi.com
Jeepless
FuLcRuM is offline
post #3 of 15 Old 12-10-2010, 07:17 AM Thread Starter
Thanks Brother, I've seen the tester but not sure on how would I use it. Is it to the wirering, the injector power on? if you know please let me know thanks again...
post #4 of 15 Old 12-10-2010, 03:32 PM
Well, for me, that is the easy part. Just simply set your meter to measure "Ohms". Then place the leads on the two wires of the device. The real question is: "What is High and what is low?
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #5 of 15 Old 12-10-2010, 05:27 PM Thread Starter
Thanks bro, I do have the "Whats high and whats Low" answer at home, on the road right now... will post when I get home. Thanks again.
post #6 of 15 Old 12-10-2010, 08:15 PM
Why are you going to bigger injectors for?
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #7 of 15 Old 12-13-2010, 02:31 PM Thread Starter
Thanks Buddy and Here is the answer: If it is between and OHM is Low Impedance and if it is between 10 and 16 OHM is High...
post #8 of 15 Old 12-13-2010, 02:32 PM Thread Starter
If I tell you I would have to take you on a trip on my trunk... Top secret for a month or so...
post #9 of 15 Old 12-16-2010, 05:20 AM Thread Starter
Does the ignition key has to be on? Might be a stupid question hahaha Why JK-Ford? just curious about the Ford part...
post #10 of 15 Old 12-16-2010, 07:49 AM
ronjenx's Avatar
You left out the numbers for the low impedance.
ronjenx is offline
post #11 of 15 Old 12-16-2010, 06:22 PM Thread Starter
Sure did, will post when I get back home
post #12 of 15 Old 12-17-2010, 11:57 AM
FuLcRuM's Avatar
It's probably 1.7 to 4.7 ohms, like I posted above.
Jeepless
FuLcRuM is offline
post #13 of 15 Old 12-24-2010, 06:08 AM Thread Starter
Low Impedance would be between 1.5 and 4.0 OHM
post #14 of 15 Old 12-24-2010, 07:20 AM
[QUOTE=offroadpr;620717Why JK-Ford? just curious about the Ford part...[/QUOTE]
Thats my name. Everyone teases me about a Ford driving a Jeep. So I put them together.
"The Green Monster"
on
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #15 of 15 Old 12-26-2010, 12:47 PM Thread Starter
Hahaha Awesome, then you might be interested on my new project, I am putting a Ford Thunderbird Super Charger on my JK. So there will be some FORD on My JK...
