another gremlin. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 12-03-2010, 07:21 PM Thread Starter
Hoopa70's Avatar
another gremlin.
This has been happening for a long time, and i have pretty much ignored it but now that its getting colder, its pissing me off more and more.
Situation: Mostly at highway speeds this will happen. The MIL chime will go and the MIL will pop on. I check codes (with flashpaq) , there's none other than TPMS code which has been disabled and TPMS shouldn't set MIL anyway.. The light stays on for a day or two (unless I reset it with my flashpaq) and then it goes out until the next highway run. One of the fucked up things I notice is, that I routinely drive a 40 mile route on the freeway to the gym. Sometimes, the light will not come on during the ride there, but when I drive home from there after the the jeep has cooled for 2-3 hours, it ALWAYS comes on and usually in the exact same spot on the freeway, wtf? Last weekend, I drove to Maine 250 miles at 70 mph and no light, the next morning it came on after 10 minutes..
So, no codes and the jeep runs and drives fine but here is the thing that pisses me off about this little problem.. If the MIL is on when I shut the jeep off, the factory remote starter will not work. It will start, run for 15 seconds and die until it is started with a key. When I do this, it throws a remote starter code..
So I took it to the dealer, explained my situation.. They diagnosed it and found the remote starter code. They replaced the remote starter unit in the jeep and flashed my keyfobs, No fix... I think maybe if the MIL is on, there's a safety feature that disables the remote starter.. The problem is documented with the dealership, but I just don't feel like playing cat and mouse with them, driving it up there, dropping it off for the day and having them find nothing wrong..rinse, repeat..
IDGAF about the light (ok, it pisses me off a little), but I want the remote starter to work. I am sure that whatever causes this is something minor, but I am at a loss.. i have checked every connection that is readily accessible.
At one point last winter I was popping fuses on the driver side light circuit, turned out to be the factory wiring running to the side marker light on the driver side fender was pinched at the factory and it chafed through causing a short, that was fun to figure out, it wasn't visible and the fender had to come off to find the problem. I thought this might be the root cause of the above problem, but no..
I highly doubt there's anyone who has had a similar problem, I have googled it, searched it... nothing.. Just throwing it out there to see if anyone has ideas
Hoopa70 is offline
post #2 of 11 Old 12-03-2010, 09:34 PM
tkob1060's Avatar
I would return jeep to stock with the superchips and see if it still happens.
tkob1060 is offline
post #3 of 11 Old 12-04-2010, 08:19 AM Thread Starter
Hoopa70's Avatar
I should have mentioned that I tried this already, but thank you.
Hoopa70 is offline
post #4 of 11 Old 12-06-2010, 01:12 PM
chileanjk's Avatar
Try leaving fuses out, one by one and trying the normal route to see if the light turn on, I found a gremlin on my wife's Liberty, it was living on the stock headunit, but I found it and killed!!
chileanjk is offline
post #5 of 11 Old 12-06-2010, 01:24 PM Thread Starter
Hoopa70's Avatar
Thank you sir... I feel like a jackass not thinking of this myself..
Here's to you
Hoopa70 is offline
post #6 of 11 Old 12-09-2010, 01:56 PM Thread Starter
Hoopa70's Avatar
Jeep is in for brake job, had my buddy scan it for codes. got a p0740 TCC solenoid circuit open. Any one ever replace this solenoid? curious how simple (or difficult) it might be...
Hoopa70 is offline
post #7 of 11 Old 12-12-2010, 08:48 PM
Have to ask.. what is MIL ?
cowboy49 is offline
post #8 of 11 Old 12-13-2010, 08:46 AM
Windows open to dround out any beeping and black electrical tape over any lights does wonders
mattymat04 is offline
post #9 of 11 Old 12-15-2010, 07:36 AM
chileanjk's Avatar
thats the Torque Converter Clutch, you should check the wiring harness to the transmission first, and clean any debris the connector collects, then reconnect and try again, do you have problems at HW speeds? high RPM?
post #10 of 11 Old 12-15-2010, 08:29 AM Thread Starter
Hoopa70's Avatar
Yea, I checked all the wiring.. it's at the tranny shop now for a service, hopefully they can diagnose it.
Hoopa70 is offline
post #11 of 11 Old 12-16-2010, 10:35 AM Thread Starter
Hoopa70's Avatar
my worst fears have been realized.. there is clutch material in the pan. looks like i'm getting the tranny rebuilt 1000 miles out of warranty..
I think there's a lesson in here somewhere. I probably should have been a little more pro-active with the dealership, but with no codes until AFTER the warranty ran out and all the mods, I doubt it would have been anything more than a blood pressure test.
Hoopa70 is offline
