stock speaker pods. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 12-01-2010, 08:17 PM Thread Starter
mikeyfl's Avatar
Question stock speaker pods.
got 10 sqft of fatmat xxx rattle trap.
did the first layer on the speaker pods and i have plenty left to do a second. question is, should i do a second layer? is there any way i can use the leftover, probably a little over 5 sqft, for the sound bar? ...probably not, huh?
mikeyfl is offline
post #2 of 10 Old 12-01-2010, 08:46 PM
XJK07's Avatar
I used a single layer of HushMatt on mine. One is all it took. I did however do a single coat on the inside as well as out. While you have them out go ahead and pack them with Polyfill; it will greatly improve the sound as well.
XJK07 is offline
post #3 of 10 Old 12-01-2010, 08:48 PM Thread Starter
mikeyfl's Avatar
how did you put it inside? its all little waffle cross squares.
mikeyfl is offline
post #4 of 10 Old 12-01-2010, 09:03 PM
WINNAR!
DOOKEY's Avatar
That stuff looks familiar. I used it everywhere on my truck.
I still have a big roll left so thanks for the idea!
Andy
316.337.5311
DOOKEY is offline
post #5 of 10 Old 12-01-2010, 10:56 PM
Hittnthebz's Avatar
I've been thinking about doing this...have you put them back in yet?
Hittnthebz is offline
post #6 of 10 Old 12-02-2010, 08:53 AM Thread Starter
mikeyfl's Avatar
i have not put them back in yet.
i have to run all the amp wiring and set all that garbage up... dont think ill get it done before work today. so another day with no music.
mikeyfl is offline
post #7 of 10 Old 12-02-2010, 10:08 AM
XJK07's Avatar
I cut it into small squares and worked it down by hand after heating it a little with a heat gun. Custom car audio is what I do for a living. I just used materials and tools I had here in the shop.
I also did the inside behind the speaker in the sound bar; as well as the mounting surface of the speakers in the sound bar and packed it full of poly-fill as well. The only vibration I have from the bar now is the loose dome light making a buzz every now and then. I have yet to fully stop that problem. I am no longer running the factory speakers. The same time I did the sound deadening; I installed a set of Kicker DS650s(aftermarket version of the Mopar Kickers). It sounds great, even on just my Pioneer Nav unit and no amp. Mike, I see the Alpine amp in the background of your pics, great choice you will love that thing!
XJK07 is offline
post #8 of 10 Old 12-02-2010, 10:32 AM Thread Starter
mikeyfl's Avatar
i think ill pass on the little squares!
when you say stuff with polyfill... how much is stuffed?
mikeyfl is offline
post #9 of 10 Old 12-02-2010, 11:26 AM
XJK07's Avatar
I stuffed it a good amount. To be honest I didn't measure the volume, just eye-balled it. I'd say I filled it maybe 40-50% full. It was a lot of work I am not gonna lie man, lol.
XJK07 is offline
post #10 of 10 Old 02-07-2011, 10:48 PM
Poly fill stuffing ratio is about 1lb per cubic foot which in reality seems like quite a lot when you are doing it but sounds great!
Ps just realised that was my first post HAHA, i must have been lurking!!
sixfootfour is offline
