ESP Kill and 12 voltguy switch panel - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 11-28-2010, 11:38 AM Thread Starter
Iron's Avatar
Have a 12 Voltguy 4 switch panel for my lights, I'm only using 3 of the 4 switches and want to use the 4th as the ESP Kill switch. Only thing I can't figure out is how to have the switch light up when the ESP is off. I want to have the ESP enabled for normal driving, but when offroad and I turn the ESP OFF with the switch I would like the switch to light up as they do with the lights. Right now i can only get the switch to light up when the ESP is ON.
Anyone now how to get around this?
Mike B
08' Jeep Wrangler
08' Dodge Avenger SXT (winter beater)
64' Plymouth Sport Fury(sold)
58' Triumph TR-3A(in 1,000,000 pieces)
Iron is offline
post #2 of 2 Old 11-28-2010, 02:09 PM
Guruman's Avatar
You could relay it. You'll need a relay with a normally closed (NC circuit.) Wire the ESP through the NC terminal on the relay. That way when the switch (and the light) are on, the ESP is disconnected.
_
Guruman is offline
