Headlight aiming ??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 11-25-2010, 08:55 PM Thread Starter
jtphoto JK's Avatar
Must I remove the grill just to aim the headlights? I don't see any adjusters accessible with the grill on..
Jeff _(OllllllO)_
jtphoto JK is offline
post #2 of 6 Old 11-25-2010, 09:03 PM
gcologne25's Avatar
You don't have to take the grill off. if you get level with the lights, you can see the screws at the corners of the lights you need to turn to aim them. Its also a torx head so you might have to go to homedepot to get the right tool.
EDIT: It's a torx t-15 head
gcologne25 is offline
post #3 of 6 Old 11-25-2010, 09:35 PM
ronjenx's Avatar
ronjenx is offline
post #4 of 6 Old 11-25-2010, 10:03 PM
.:eMETAL:.'s Avatar
exactly what ^ said.
park 25' from a wall (level ground, wall to headlight). measure 3' up the wall and place a piece of blue tape at that measurement. turning the screw counter clockwise will lower the beam pattern and clockwise will raise it. the beam pattern is set when it is just resting below the tape mark.
.:eMETAL:. is offline
post #5 of 6 Old 11-25-2010, 10:21 PM
ronjenx's Avatar
You are correct, except the line on the wall is to be the same height as the optical center of the headlight.
ronjenx is offline
post #6 of 6 Old 11-26-2010, 10:37 AM Thread Starter
jtphoto JK's Avatar
Thanks Guys...
Jeff _(OllllllO)_
