audio crossovers questions. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 11-20-2010, 07:33 PM Thread Starter
mikeyfl's Avatar
Question audio crossovers questions.
if my speakers came with an external crossover what do i set the amps crossover to? the same as the external or do i not use the amps feature?
mikeyfl is offline
post #2 of 4 Old 11-20-2010, 07:44 PM
block's Avatar
if your speakers have crossovers.. just send the full signal to the speakers crossovers and let them split the signal...are you using a sub with your setup ? if so does your headunit have a sub out ? then i would just turn off the crossovers on the amp and control it from the headunit..
block is offline
post #3 of 4 Old 11-20-2010, 07:52 PM Thread Starter
mikeyfl's Avatar
so turn the amp crossovers from high pass to off and just use the externals?
yes, ill be using a sub, but im keeping the stock headunit.
mikeyfl is offline
post #4 of 4 Old 11-22-2010, 04:35 PM
b1pig's Avatar
ditto...
if using included passive crossovers, amp's crossover should be set to "off".
are you using a separate amp for the sub or you using a "tri-way" install?
if going "tri-way", you'll need a dedicated passive crossover for the sub, too.
b1pig is offline
