LED Issues - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 11-09-2010, 08:08 PM Thread Starter
Dr.Dirty's Avatar
Feedback: 21 reviews
LED Issues
Looks like i got another Gremlin. I was closing up the shop tonight and hit the lights and noticed a faint glow on the rear LEDS. Its very faint and doesnt draw lots of power because the Jeep hasnt moved in over a week and started up just fine. Any ideas why these would stay powered? I swapped in a set of regular incandescent 4 inch rounds and its not enough juice to light those up
Dr.Dirty is offline
post #2 of 26 Old 11-09-2010, 08:23 PM
Mr.RonGilbert's Avatar
I had the same chit going on with my Recon turn signals..... weird. I also added resistors and still have the hyper flash on the passenger's side. I emailed Tech and will report out what they say about the dim LEDs when the Jeep is off.
They went out after a while and have not done it since last night....
Mr.RonGilbert is offline
post #3 of 26 Old 11-09-2010, 08:34 PM Thread Starter
Dr.Dirty's Avatar
Ive been running the same lights for months and the jeep sits weeks at a time so its not hurting anything. but now im annoyed lol
keep me posted on what they have to say. I have not added resistors i just have delt with the machine gun blink
Dr.Dirty is offline
post #4 of 26 Old 11-09-2010, 08:48 PM
RubiZealot's Avatar
My hypothesis is that there is residual capacitance on the circuit for your lights. Being that LEDs take next to nothing to power, they dimly light.
Mike 2010 Rubicon 2DR | RK 3.5 X FACTOR MID ARM | ΜΟΛΩΝ ΛΑΒΕ
RubiZealot is offline
post #5 of 26 Old 11-09-2010, 09:24 PM
.:eMETAL:.'s Avatar
x2
mine have always done it. kinda annoying but at the same time kinda neat. they do dim out. but i have also noticed that if i open the rear gate and shut it the passenger side will flash as to almost shoot the remaining power left in the circuit out? only one time though after i shut the jeep off.
.:eMETAL:. is offline
post #6 of 26 Old 11-09-2010, 09:48 PM
andrelopez99's Avatar
x2
X2 - on the opening the rear gate and etc. (exact same), happens to me with the ORO litedots.
andrelopez99 is offline
post #7 of 26 Old 11-10-2010, 04:36 AM Thread Starter
Dr.Dirty's Avatar
Yeah i notice the flash when you open the gate or a rear door just never gave it much thought
Dr.Dirty is offline
post #8 of 26 Old 11-10-2010, 05:26 AM
Thats pretty odd, any of you guys try making a ground strap back there? From the tub to the frame or something?
post #9 of 26 Old 11-10-2010, 05:44 AM
mediamaxim's Avatar
I've had both issues since day one of installing LED rears. Doesn't really bug me so I just learned to live with both.
mediamaxim is offline
post #10 of 26 Old 11-10-2010, 07:35 AM Thread Starter
Dr.Dirty's Avatar
Its nice to know its just not my Heap being retarded again lol.
Dr.Dirty is offline
post #11 of 26 Old 11-10-2010, 08:01 AM
Grant211's Avatar
my 2cents - i found some LED bulbs to swap in on my factory taillights.... I had the same issue. I didn't like it, so i changed them out to some "super white" regular bulbs.
Grant211 is offline
post #12 of 26 Old 11-10-2010, 12:05 PM
Their response was basically this. They said to ensure that the ground is sound and to go to the chassis with a screw. I might try a self tapper under the front somewhere just to see. They also said that I could try adding another resistor..... Which is strange because the right one is perfect.... If both of them were a little dim for a few minutes after you shut it down it would be kinda cool, like you meant for it to do that but only one looks like something is fucked up..
post #13 of 26 Old 11-11-2010, 03:52 AM
venom's Avatar
same deal with my LED front turn signals
faint glow for a few minutes after shutoff and a flicker when you open the door
I just go the microsoft route and call it a feature,not a bug
Originally Posted by My Wife
venom is offline
post #14 of 26 Old 11-11-2010, 07:10 AM
I'd just run a quick jumper from the battery to a good screw/area in the back to see if the ground does anything for you before messin with much else. May fix it, grounds can do screwy things!
post #15 of 26 Old 11-11-2010, 07:25 AM Thread Starter
Dr.Dirty's Avatar
I think i have a bad ground somewhere. I just havent bothered to chase it down.
Dr.Dirty is offline
post #16 of 26 Old 11-11-2010, 08:44 AM
My poison spyder led taillights do this too. the flash when you open a door, and the always on, but only a few leds and super dim thing....and the machine gun flash. i've upgraded the resistors too, but no changes....
So a basic graound issus is where we're all leaning? Could the CB ground be messing with all of this? Any solution would be appreciated!
a-squared is offline
post #17 of 26 Old 11-11-2010, 08:47 AM
venom's Avatar
I don't think its a ground issue, you guys are having it on the tails, mine does it on the front turn signals
more likely a canbus thing than a ground thing
venom is offline
post #18 of 26 Old 11-11-2010, 09:55 AM
07unlimitedx's Avatar
Very little power is required to light up an LED... if there is the least bit of power left in the Jeep's electrical system... the lights are probably getting the power from that. I play around with LED's quite a bit... 2 LED's with a resistor plugged into a 12v power supply, if you unplug the power supply the LED's will stay on for 30 seconds or so, not full power just a dim glow.
That's my 2 cents...
07unlimitedx is offline
post #19 of 26 Old 11-11-2010, 11:17 AM
dukabor's Avatar
Just to jump on the bandwagon, I have this "feature" as well with my LEDs!
dukabor is offline
post #20 of 26 Old 11-11-2010, 11:53 AM
genesbro's Avatar
In order for led turn signals to work properly you have to install an electronic flasher in place of the oem unit.
09 JK 3.5 Rubincon express suspension 35" open country tires 9000lb superwinch member okc jeepthing club
genesbro is offline
post #21 of 26 Old 11-11-2010, 11:54 AM Thread Starter
Dr.Dirty's Avatar
they work fine in the JK with resistors. but they still hold a charge after the vehicle is off
Dr.Dirty is offline
post #22 of 26 Old 11-13-2010, 07:57 PM
leman's Avatar
i remember this happening when i had my G35 with LEDS in the dome lights and marker lights. as said it has to do with such little amount of elec. needed to power the lights.
2008 steel blue sahara
with some doo-dads
leman is offline
post #23 of 26 Old 11-14-2010, 06:45 PM
The system in the jk is solid state, not relays. Called a ssr.
What this means is even when off there is what's called leakage current. The load of the LEDs is not enough for the ssr to completely shut off.
Add a resistor in parallel to the LEDs to drain the leakage. Start high like 20k ohm and move down until it works.
The higher wattage load resistors commonly used with LEDs may work too.
Wubicon is offline
post #24 of 26 Old 11-14-2010, 06:47 PM
So regardless it will still draw either through the resistor, or really dim LEDs either way is what yo are saying? Or will the solid state module turn off/go to sleep with the resistor?
post #25 of 26 Old 11-14-2010, 07:01 PM
I had this issue in an Acura I used to have. I spun the bulbs around. Apparently LEDs have polarity..
Try it out. And I think if one was reversed they all did this.
no jeep here...
Racer83l is offline
