Traction Control with its own mind? help? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 10-25-2010, 08:26 PM Thread Starter
About a month ago my ABS, ESP, and Traction Control lights flipped on the dash. Starting the engine cold and trying to go somewhere sets off the traction control system stopping any kind of accelleration. Obvious its the traction control it only has this problem while accelerating. For some reason the colder it is outside the worse it does it and the longer it continues to take over traction. Typically, as the car warms up (more so then the engine) it will stop doing it.
I checked all the tires. They are all good with 35 pounds each.
Any ideas before i turn this problem and my wallet over to a dealer?
JDiz is offline
post #2 of 10 Old 10-25-2010, 08:31 PM
scottrock's Avatar
So what changed? Lift? Tires? Out of the blue? Have you checked all your nutz & bolts???
More info man, more info. If nothin I'd either be wrenchin or haulin ass to a shop somewhere.
edit: not just nuts & blots but bent shit, check your toe, etc....
scottrock is offline
post #3 of 10 Old 10-25-2010, 08:55 PM
StubEXrube's Avatar
If your steering wheel is perfectly centered, and assuming you haven't made any recent adjustments to your suspension set-up.....it could be the steering angle sensor. I would scan it to see if you are getting any codes.
StubEXrube is offline
post #4 of 10 Old 10-26-2010, 07:04 PM Thread Starter
Nothing has changed at all. no lift no new tires anything. seriously the only thing that has changed around here is the temperature outside. how come my jet ski give me codes yet i have to pay someone a bunch a money to plug something in and tell me a code?
the wheel is centered and it doesnt pull one way or the other.
JDiz is offline
post #5 of 10 Old 10-26-2010, 07:10 PM
scottrock's Avatar
You can pull the last code without a reader. Search is your friend
edit: found it,
Originally Posted by N2rock View Post
Turn key to on position (but don't start)
push the key into the ignition cylinder and while holding it in, and while holding it in turn to off and back to on 3 times, ending in the on position
If you did it right, all the dash lights will light up and the odometer will be a series of dashes. After the dashes, it will then display any codes (be ready to write them down since you may have more than one).
post #6 of 10 Old 10-26-2010, 07:25 PM
Jagrmaister's Avatar
My Jeep will give me the ESP BAS "BS" lights every now and then. I hate all this computer junk they have on the Wranglers. I guess it's good for some, but the second you start lifting and tinkering and still use it as a DD you wind up fighting the electronic components of the vehicle.
Mine usually clears itself after a few miles of drive time. It's been recentered after the lift, and it's just now started giving me some trouble after bending my drag link (understandably so). But it has done it without any modification or tweaks before. Computers...
2010 Jeep Wrangler 2dr Rubicon with a part from everyone...
Jagrmaister is offline
post #7 of 10 Old 10-27-2010, 05:38 PM Thread Starter
[QUOTE=Jagrmaister;570022]My Jeep will give me the ESP BAS "BS" lights every now and then. I hate all this computer junk they have on the Wranglers. I guess it's good for some, but the second you start lifting and tinkering and still use it as a DD you wind up fighting the electronic components of the vehicle.
QUOTE]
Sad to admit. I havent really dont anything to it as far as how it rides. No lift, no big tires, like that. Only thing i did was swapped out the 18s and put the Rubi set up on it.
edit: found it,
I will definetly pull that tomorrow to see what comes up. Huge thanks.
JDiz is offline
post #8 of 10 Old 11-02-2010, 07:16 PM Thread Starter
6 dashes. and im 100% convinced that it has to do with engine temperature somehow. as soon as the engine or some commonent warms up its fine.
JDiz is offline
post #9 of 10 Old 11-05-2010, 09:20 PM
Chunks's Avatar
Is it a Rubi? If so mess around with the electronic swaybar motor wiring ie. unplug it and see if things clear up. Ive heard of those things causing all kinds of strange gremlins. Otherwise break out the chicken bones and start a voodoo dance.
08 Silver Unlimited
3.5" RE Superflex
35" Pro Comp X Muds
5.13 Superiors
Rampage front
Rancho rear
Tabor 9K
Spidertrax and stockers
Line-x
Chunks is offline
post #10 of 10 Old 11-07-2010, 12:53 AM
I know some like the ABS and other systems that come on the JK (and all new cars & trucks) but man, I miss the days before all the computer controled crap.
