help with codes - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 10-20-2010, 07:55 PM Thread Starter
help with codes
ok so the last few days my check engine light has been on,last night did the key thing and it showed me oo32 which is 2/2 o2 sensor,Today check engine light is still on and i tried the ket thing and it just says done, shouldnt it still show the 0032 i havent changed anything yet??
frito is offline
post #2 of 2 Old 10-20-2010, 08:16 PM
ronjenx's Avatar
It could be the condition is intermittent, or no longer exists.
From the factory service manual:
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
When Monitored:
Battery voltage above 10.6 volts, ASD is powered up, and O2 heater is off.
Set Condition:
The PCM detects that the O2 sensor heater element input is above the maximum acceptable voltage. One trip fault. Three good trips to turn off the MIL.
Possible Causes
K99) O2 1/1 HEATER CONTROL CIRCUIT OPEN
(Z906) O2 1/1 HEATER GROUND CIRCUIT OPEN
(K99) O2 1/1 HEATER CONTROL CIRCUIT SHORTED TO VOLTAGE
1/1 O2 SENSOR
POWERTRAIN CONTROL MODULE (PCM)
ronjenx is offline
