2016 JKU radiator fan problems - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 02-18-2020, 09:44 AM Thread Starter
I havinh a problem with not getting low speed fan when temperature hits 215-217 and the high speed fan kicks on at 226-228 it is at the low speed. If I turn the AC on the fan runs but still dont get high speed at any time. I have changed the ECT sensor, radiator fan. Checked fan fuse in the tipm and the relay in the tipm. Trying to get any help with this issue as my temps get to 230 and it has a hard time cooling it down because of not getting right speeds.
Michael Woodruff is offline
post #2 of 3 Old 02-18-2020, 09:59 AM
rich6700's Avatar
Your going to need a professional scan tool to see it the fan is getting a signal.
rich6700 is offline
post #3 of 3 Old 03-04-2020, 09:14 AM
0lllllll0 RPMEXTREME's Avatar
The 12+ JK doesn't use "HI LOW" fan speeds. You have. PWM computer controlled fan. It will run at varying speeds as commanded by the ECU. They tend to not run at higher speeds until its above 230 degrees.
If you have a good scan tool you can go into the TIPM and watch the live data showing you the commanded fan speed. You can also command the speed with a lot of the good scan tools.
