2018 radio swap nightmare - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By GC_JK_62
post #1 of 8 Old 01-29-2020, 04:42 PM Thread Starter
Hope we have some audio gurus on watch. I shot myself in the foot, I ordered my 2018 Sahara and followed some online advice regarding the audio system. The advise was: order the 9 speaker Alpine system, but, just get the base head head unit due to the high price of the Alpine. Then, find a plug and play aftermarket for a lot less $$. I bought a Pioneer AVH-4200NEX and had a local, reputable audio shop perform the swap. Of course, it involved the various adapters and the real McCoy Mopar harness for the steering wheel controls. The audio will play just fine for seconds, minutes or hours, and, suddenly, the left side of the speaker system will shut off. Then, it will come back on for seconds, minutes or hours and then, drop off again. The audio shop replaced the harness with an "updated" Mopar edition. Same result. The dealership (yes, it's still under warranty) has "washed it's hands" of the issue because original factory equipment has been replaced. The audio shop is at a loss, the dealership won't help, and here I am with a shot foot. Any suggestions?
GC_JK_62 is offline
post #2 of 8 Old 01-29-2020, 07:03 PM
RMY
RMY's Avatar
Hi recently put in an Alpine ILX-107 in my 2016 JKU. Got all the adapters from Crutchfield. Fairly simple install. So the shop that did you install basically not standing behind their work? Have you tried reinstalling the factory head unit to see if the problem persists? Bad head unit?
Sent from my iPhone using Tapatalk Pro
2016 JKU Rubicon
Teraflex ST3, BFG AT KO2 35x12.5R17
Alpine ILX-107
RMY is offline
post #3 of 8 Old 01-31-2020, 03:51 PM Thread Starter
The audio shop has been really concerned and has taken my Jeep back 4 times to diagnose. They even paid for the updated wiring harness. The dealership has been less than helpful. Yes, re-installing the base unit is in the near future. The issue has gotten worse, the sound will cut off completly at times.
GC_JK_62 is offline
post #4 of 8 Old 02-05-2020, 06:14 AM
Maybe overheating after time and the head unit is shutting down part of its amplifier circuit? I had a plastic inline fuse housing in my last vehicle that the housing cracked and would randomly make or not make the connection to power my external amp. Took quite a bit of troubleshooting to find that one, too. Another time, I had an RCA connector connection be bad, causing only partial signal strength getting to the sub amp, so the volume at times would be maybe 25% of what it should have been. In custom audio there can be all types of gremlins. Almost need to trace each individual wire, wiggle on them to confirm the sound doesn't drop out due to a certain angle/position of the wire and move onto the next.
PrimeTimeRubicon is offline
post #5 of 8 Old 02-05-2020, 04:38 PM Thread Starter
Swapped out the Pioneer with the base unit. Problem solved. Too bad the Pioneer is out of warranty. Currently pondering my options.
GC_JK_62 is offline
post #6 of 8 Old 02-07-2020, 08:12 PM
RMY
RMY's Avatar
Hi ow is the pioneer out of warranty? Over a year old before installing? Used via eBay?
2016 JKU Rubicon
Alpine ILX-107
RMY is offline
post #7 of 8 Old 02-08-2020, 12:34 PM Thread Starter
Purchased in late November 2018 (Black Friday sale) from Best Buy. Here's where the audio shop stumbled. They said Mopar had not released the "tech data" necessary to buy the correct wiring harness for the install. I waited on them for several months before pressing the issue. Turns out, the "tech data" wasn't really needed at all. The next few months was back and forth with the audio shop, trying to diagnose and fix the issue. Time flies when you don't think your brand new head unit is the issue. I don't drive the JK everyday, but, when the primary vehicle went in the shop for a week, the issue drove me nuts and into action. After doing a little research, I had an Alpine ILX-207 installed. I'm still learning how to use it, but, seems like a solid choice so far. Yes, I used a different audio shop.
RMY likes this.
GC_JK_62 is offline
post #8 of 8 Old 02-08-2020, 03:35 PM
RMY
RMY's Avatar
Interestingly the only difference between the ILX107 (discontinued) and the new ILX207 is they DROPPED wireless CarPlay. Canít understand why.
2016 JKU Rubicon
Alpine ILX-107
RMY is offline
