Aftermarket Inverter to Power Stock Plug? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 01-27-2020, 05:05 AM Thread Starter
Hello, sorry if this seems like an amateur question however is it possible to use an aftermarket Power Inverter (Centec 750/1500) to power a stock AC plug that I plan to put in my center console bezel?
Rather than installing a factory inverter, can I simple run a inverter and then tap into the poer outlets, run wire to the stock plug and just tap into a harness or simply connect to the two prong side???
Anyone done this? Any tips and ideas would be helpful.
post #2 of 4 Old 01-27-2020, 06:10 PM
BigTB's Avatar
You'd just have to run the wires from the back of the inverter receptacles to the factory receptacle you install in your console. Just make sure all connections are secure, solid and insulated well.
BigTB is offline
post #3 of 4 Old 01-28-2020, 05:09 AM
Guruman's Avatar
There might be some issue getting the AC wires to attach to the factory style plug... I'm not sure what connectors those use, but I bet it's not your standard A/C wiring.
_
Guruman is offline
post #4 of 4 Old 01-28-2020, 11:05 AM
BigTB's Avatar
True, it might require some modification and soldering, or it may just not be practical at all.
BigTB is offline
