Elec. gurus a little help. - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By Riley 3
  • 1 Post By snout
post #1 of 5 Old 01-21-2020, 02:22 PM Thread Starter
I’m replacing a 10 ga fusible link wire spliced to a 6 ga alternator wire. The open ended copper connector I want to use is 6 ga and I want to use that to crimp and wire the 10 ga fusible link wire.
The old fusible link was 4”.
Won’t the 6 ga connector change the 10 ga wire to 6 ga? If so should I measure the fusible link wire from the end of the 6 ga connector?
Hope this make sense, and thanks for the help.
Riley
Riley 3 is offline
post #2 of 5 Old 01-21-2020, 03:15 PM
rockystock's Avatar
No, the 10ga link will still behave like 10ga link.
Not sure on length; but you may have trouble with the connector being too large for the 10ga.
Sent from my LG-H918 using Tapatalk
rockystock is offline
post #3 of 5 Old 01-21-2020, 03:33 PM
changing the seat on your toilet to a smaller , padded one or adding a smaller hole for the turds to go down doesn't change the bowl capacity.
a wire's gauge is it's gauge.
post #4 of 5 Old 01-21-2020, 05:11 PM Thread Starter
Thank you.
I think I can make the crimp work on the smaller wire I will solder the ends. I have plenty to practice with.
I know the fusible length is critical and the old fusible link was 4”.
rockystock likes this.
Riley 3 is offline
post #5 of 5 Old 01-21-2020, 07:04 PM
you can go piss up a rope
snout's Avatar
Couple #6 purple wire nuts and you should be good to go.
j3ff3ry_j33p likes this.
y’aller quenchin' with beer
snout is offline
