Rewire sway bar disconnect - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 01-21-2020, 06:50 AM Thread Starter
So I have a 17 Rubi that I put dana 60s on. I wired the lockers to my SPOD so I can lock the difs when ever I want. The problem now is the sway bar wont disconnect. Is there a way to rewire or bypass and get the sway bar disconnect working?
Jeremy_Schoenfelder is offline
post #2 of 5 Old 01-21-2020, 07:47 AM
JeeperJoe's Avatar
Hey Jeremy, Welcome to the forum. Does your sway bar light react to pressing the switch? Does it just flash?
The smart bar, I think that's what its called, is notorious for crapping out if a little moisture finds its way into the right nook or cranny. It's pretty nice to just hit a button and lock and unlock and I've been lucky with mine but when time comes that it stops working I'll probably just install the manual disconnect from EVO. Its just a knob that you turn to engage or disengage the sway bar. Don't forget to stop by the welcome room and intro yourself and rig
You can have a savings account or a Jeep.
JeeperJoe is offline
post #3 of 5 Old 01-21-2020, 07:57 AM Thread Starter
JeeperJoe
It does nothing when I press the button.
post #4 of 5 Old 01-21-2020, 09:41 AM
JeeperJoe's Avatar
JeeperJoe
The usual symptom when the smart bar goes bad is a constant blinking light. Could be a switch issue, try disconnecting from the stock switch jumping it over to another switch and see if you get any response on your dash.
post #5 of 5 Old 01-21-2020, 09:22 PM
Lockers should have nothing to do with sway bar disconnecting. You can disconnect in 4hi or 4lo up to 18mph, independent of locker state.
christensent is offline
