2008 JK Aftermarket stereo getting no rear speaker/sub sound - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-09-2019, 01:56 PM Thread Starter
I have a 2008 JK with the infinity sound system and factory amplifier. I bought the PAC needed to connect to my radio, backup camera and all functions fine except my sub/rear speakers.
I realize in order to use this PAC C2R-CHY4 I had to hook up the front speaker outputs of the head unit to the rear speaker wires of the harness in order for it to work at all. Is there not a work around that will allow my sub + all my speakers to work? I've had no issues in the past on 2 other Nissan vehicles but this Jeep is wearing me out!
It specifically says "Connect the front outputs of the aftermarket radio to the rear inputs of the 22 pin radio connector...The rear speaker outputs of the aftermarket radio are not used".
I read somewhere the rear speaker outputs trigger the sub, which would make sense to me. Maybe I'm just stuck with front speakers when using my factory amplifier with an aftermarket stereo.
dev20tx is offline
post #2 of 5 Old 11-10-2019, 06:55 PM
Jesse Dupont's Avatar
You also have to make sure the amp trigger wire is connected to the correct trigger wire.
2009 JKUR 3" BDS,RK pro tie rods
Jesse Dupont is offline
post #3 of 5 Old 11-11-2019, 01:58 PM
Banshee's Avatar
I got one of the Chinese android head units. It came with 2 harnesses, and I have an '08 with Infinity system. I had to use the one that fed the front output only, into the amp, which will split that & feed front & rear speakers & sub. (When I used the one with 4 outputs, I got no audio at all.)
The problem is, the original head unit tells the amp how to fade the front / rear via the CANBUS, so I have very low rear output, until such time as I can get an aftermarket amp with 4.1 output.
Originally Posted by Clone7
When you die, you see your life going by in a flash.
Steve Jobs didn't - Apple doesn't support Flash.
This message has been reviewed & approved by the NSA, Google and Microsoft.
Banshee is offline
post #4 of 5 Old 11-19-2019, 01:25 PM
0lllllll0 RPMEXTREME's Avatar
I think you can add a power wire to the amp to tell it to turn on. some guys use the power antenna output.
There are some write-ups online somewhere.
post #5 of 5 Old 11-19-2019, 07:34 PM
ndtguy's Avatar
Installed my kenwood deck and a set of amps this weekend.
Used the power antenna wire as my remote wire for the amps.
NDTguy
2017 JKU Sport S
ndtguy is offline
