The Dreaded ESC light, need some help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 09-17-2019, 10:32 AM Thread Starter
Texas_Jester's Avatar
Hi all,
I have searched all over the forum and I'm not quite finding anything that addresses my issue.
I have an ESC light coming on (2017 JKU), odd thing is it only seems to come on at slow speed turning out of a parking space or backing out of a parking space. I can clear it and it will go away for about 2-3 days, drives fine, then comes back on again coming out of a parking spot. It will sometimes clear itself on the next restart, but most of the time it does not.
I have been chasing this for a while and I'm not on a stock setup, 4.5" lift on 37's with a Pro-Rock 44 Unlimited front axle, PSC Hydro assist, Synergy Tie Rod and Tera Flex HD drag link, all the steering stuff is new this year, all joints (are now) new and in good shape, just had front end alignment re-checked last week, that's good, steering wheel is centered, axles are centered and vehicle tracks fine down the highway.
This started back in April, it seems, when I had a few hard knocks at Moab, I have since added the Hydro-Assist, New Tie Rod (it was starting to have that pretzel look) and New Drag link (rod ends were shot).
Additionally, I replaced the clockspring about a month ago thinking that was my issue but it has not fixed anything, light went out for about 3 days then back on again as explained above.
The two codes I keep getting when this happens are C1219 - Steering Angle Sensor Erratic Performance and C1240 Steering Angle Sensor Overtravel Performance. (this is from Superchips flashcal, so not sure how they correlate to any other device).
Any ideas where the heck my gremlin might be located or what I should check next to try and isolate the problem? It just aggravates me because I can't use my cruise control when the light is on and because I'm somewhat OCD and the light is not supposed to be on.......LOL.
Thanks in advance for any input.
Texas_Jester is offline
post #2 of 3 Old 09-17-2019, 02:52 PM
so it doesn't sound like a wheel speed sensor.
I did find this though. I don't know if it will work or not on a 2017.
post #3 of 3 Old 09-18-2019, 05:57 AM Thread Starter
I had tried this before with no success, but decided to try it again just to make sure. As before, this did not work, BUT, what it did do was kick the ESC light on (while sitting still) when turning the wheel to the left..................maybe I am getting closer to isolating something here. Its definitely not anything to do with the wheel speed sensor as the jeep was in park during this procedure. I may now be more confused than ever as I have the same number of steering wheel revolutions stop to stop in both direction
But this almost makes me think the thing might be out one full revolution somehow. I know when I put the Hydro in I secured the steering wheel at center and I know I centered the gear box before installing, so I'm really not quite seeing how it could be out that far if it is. I also had the steering wheel centered when I put in the new clockspring.
Dang new electronics are ridiculous.....LOL
https://www.youtube.com/watch?v=Xi9_29FFQVs
