2010 accessory power lose - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 09-15-2019, 06:14 PM Thread Starter
Exclamation 2010 accessory power lose
So..... my 2010 will loose all accessory power for like 2 seconds at a time. Sometimes 4 or 5 times in a row, the drive 10 miles and it does it again. This week it did it about 30 times in a row. So what happens is all accessories will die, radio, gauges, signaling devices, and such. When the power returns after 2 seconds the wipers come on and the headlights come on for just a few seconds like your starting the vehicle. So I am stumped. Beginning to think that it only does it when I have my doors connected. All summer while I had the doors off it never did it. This is a speratic condition ad is rare but not to rare of occurrence. Very annoying and embarrassing to say the least.
andrewk is offline
post #2 of 4 Old 09-16-2019, 03:35 AM
BigTB's Avatar
I would start by making sure the battery connections are tight and checking all the grounds. Could be something must more difficult to find, but start easy.
BigTB is offline
post #3 of 4 Old 09-16-2019, 07:26 AM
Guruman's Avatar
Faulty ignition switch?
_
Guruman is offline
post #4 of 4 Old 09-17-2019, 12:46 PM
re: 2010 accessory power lose
out of curiosity, what year was the Jeep's factory battery replaced & what brand are you running?
I would check a known good battery, even if you " are sure this one is good" ; i have had my '11 do that when I had both a crappy, stock battery terminal clamps AND when I had a hairline crack- invisible to naked eye- around the negtive battery terminal post. IOWS, this has battery quality/clamps-to leads written all over it.
