2015 jeep willys/ short in wiring harness when starting - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 05-26-2019, 11:29 AM Thread Starter
when I go to start my vehicle I get a click noise and lose all power. I removed my winch and all added lights wiring from the battery.
now I noticed if you shake the wiring harness
things kick right on.
any experiences with this or how to tackle this problem?
Readytworoll is offline
post #2 of 3 Old 05-27-2019, 02:40 PM
BigTB's Avatar
Which harness, or what part of the harness do you have to shake to get the symptom to appear/clear up? Have you checked all your engine and chassis ground connections? Sounds like a loose connection somewhere.
BigTB is offline
post #3 of 3 Old 05-31-2019, 03:49 AM Thread Starter
it's the main harness right ofF the battery terminals, I really haven't dealt with this issue to much, only because I'm changing up the whole front steering system.
I took off the winch and removed the lights that I added figuring that maybe something I added was causing it to ground out.
Sounds like a good place to start, I guess I need to look for a wiring diagram. I do not want to open up that harness.
Was hoping someone ran into the same situation and knew exactly WHAT TO DO.
Similar Threads
2014 Willys starting issue Coolcreek1 JK General Discussion 3 02-18-2018 10:40 AM
Running boards for 2015 Jeep willys model markerset17 Stock JK Tech Dept. 9 05-20-2015 08:57 PM
willys and willys W bowjunkie JK General Discussion 4 10-10-2014 05:38 PM
7-pin wiring harness: too short?? Jeep2.0 Electrical & Lighting Tech Dept. 9 02-01-2011 05:02 PM
