2011 Wrangler driver side HID headlight out - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By HIDprojectors
post #1 of 10 Old 03-07-2019, 06:52 AM Thread Starter
HID headlight out 2011 wrangler HELP PLEASE
I currently have driver side headlight out and it’s an HID kit. I’m at a loss and I’ve been defeated. I have checked the grounds, used new bulbs, used a new harness, replaced the fuse and the relay connected to the harness, switched the ballast out for a new one, and also have checked and made sure that the stock headlight connection that the harness connects to isn’t melted. I don’t know what to do next. Can anyone help?
Jkdumdum is offline
post #2 of 10 Old 03-09-2019, 04:40 AM
HIDprojectors's Avatar
Have you used a multimeter to check for voltage at the ballast connection (9006)? Start there, if you have voltage there, its likely either the ballast or the bulb. If you dont have voltage there its likely something in your harness or wiring.
j3ff3ry_j33p likes this.
w:
e:
p: 716.662.3479
IG:
HIDprojectors is offline
post #3 of 10 Old 03-12-2019, 07:02 PM Thread Starter
Jkdumdum is offline
post #4 of 10 Old 03-13-2019, 04:11 AM
BigTB's Avatar
Do you have a multimeter that you can use for further troubleshooting? I think the next step is to see if you are actually getting voltage to the thing.
Also, why create a new thread?
BigTB is offline
post #5 of 10 Old 03-13-2019, 05:30 AM Thread Starter
I checked it last night to see if I’m getting voltage and I am. I created a new thread because not many people are replying
Jkdumdum is offline
post #6 of 10 Old 03-13-2019, 05:47 AM
Pmedic920's Avatar
Originally Posted by Jkdumdum View Post
I checked it last night to see if Iím getting voltage and I am. I created a new thread because not many people are replying
Iím a nobody here but feel impelled to say this, one thread on the same topic is plenty, and every forum Iíve seen frowns on creating multiples asking the same question.
Good luck, and I hope you get your problem solved but I assure you, this second thread wonít get you any closer.
Pmedic920 is offline
post #7 of 10 Old 03-13-2019, 05:51 AM
Welcome.
Normal cordiality does not require that I start
talking about such stuff but there's always a 1st time.
The same could apply to your theory that one thread on a subject that is posted within JKOs ' Electrical and Lighting' section not receiving "enough replies..." might find improved results / more replies made to it if a whole different thread asking the same question were posted again in the same topic section.
When you run out of gas in your car and see the 'empty' fuel dash indicator on 'E' do you still run around to check in the tank with a flashlight & continue to turn the vehicle over and over ? This is not social media where blanket coverage will yield replies . If you aren't getting replies it either means (A) there is an inundation of data online or on this forum which contains all troubleshooting steps possible fir the subject ( indicating you've not searched past threads thoroughly ) or (B) you're asking about something which is a futile effort to attempt to answer by others online because it's obvious to the members that further testing of the circuit draw + other multimeter testing is required. So ,no help will be of use = what is to reply about! . Your first post had over 90views but 2 replies. You're getting reads. Your expectations are unrealistic , I'd guess.
I can confirm that you will get more replies by documenting your troubleshooting . Then , as you run thru your steps of that , you can post updates to ask questions when you hit something you don't understand.
Most posts of ," Help Me! " go unanswered. We like to see guys help themselves then if they require input, you'll get responses.
I'm not being an ass or onery , just helping.
I am merging your threads because you've got unnecessary 2nd thread.
Pictures or videos of your troubleshooting steps will get way more attn, also.
post #8 of 10 Old 03-13-2019, 08:10 AM
BigTB's Avatar
Which HID kit do you have? Where did you check voltage?
BigTB is offline
post #9 of 10 Old 06-12-2019, 12:19 AM
Laggy's Avatar
Igniter?
With HID, where you have one good working side. You simply swap parts over until the good side fails-to-fire. Bulb. Igniter. Ballast. Relay pack.
Laggy is offline
post #10 of 10 Old 06-12-2019, 12:25 AM
Laggy's Avatar
Seems in my eagerness to help. I have raised a thread from the dead ��
Laggy is offline
Similar Threads
The LED headlight will replace HID headlight? stephenwang Electrical & Lighting Tech Dept. 63 09-30-2014 06:23 PM
Cibie headlights- Driver's side is dimmer than passenger side? JohnnyWalker Electrical & Lighting Tech Dept. 3 05-03-2011 09:41 PM
Side Step, Left Side only $95.00, 2007-2011 Wrangler, Unlimited ed2fun For Sale 0 01-04-2011 03:24 PM
Driver's side fog out...ideas? yoda13 Electrical & Lighting Tech Dept. 7 09-23-2009 01:56 PM
