2017 JK dead battery - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By coilrod
post #1 of 7 Old 03-09-2019, 03:24 PM Thread Starter
Hello, We have an ongoing issue with our 2017JK. The battery is nearly dead after 1 week of sitting without starting. We had it repaired 2 years ago at a local mechanic shop and the guy replaced the fuse holder assembly under the hood and assured us that would solve this issue but he was wrong. The problem has shown back up recently but now we've lost faith in the local repair guy. Has anyone had this problem and if so would you share what was in need of replacement or repair?
Thank you for your time and any possible help. Respectfully, Tom
tommyjoe is offline
post #2 of 7 Old 03-09-2019, 04:08 PM
viaqua's Avatar
Something is sucking the juice from the battery its just a matter of isolating it.
You can try to hook a volt meter between the positive post and cable, then pull fuses one at a time and see which one drops the meter to 0.
viaqua is offline
post #3 of 7 Old 03-09-2019, 05:05 PM Thread Starter
Thank you for the tip! We plan on trying your suggestion tomorrow and hopefully we'll find out something. Thank you again!
tommyjoe is offline
post #4 of 7 Old 03-09-2019, 05:11 PM
This is unrelated to your issue, but might help someone else with low battery performance doing a search on this site.
I was going through 4 year warranty batteries once a year. They were getting sick of me coming back for credit towards the purchase of a new battery.
Turns out I had to shift to an Optima battery... guess it's some type of gel versus a standard liquid battery? Anyway, turns out all the 4-wheeling and bouncing around was really hard on my batteries. Since switching, things have improved significantly.
Schlieko is offline
post #5 of 7 Old 03-10-2019, 05:08 PM
coilrod's Avatar
Just make sure that you give it time to go through the self diagnostic routine when you open the hood, door, any switches or have the key in the ignition. You will otherwise see draw in some circuits.
MicroMark likes this.
Originally Posted by thedirtman View Post
Running 37's as a daily driver is dumb
coilrod is offline
post #6 of 7 Old 03-11-2019, 01:36 PM
MicroMark's Avatar
I had a similar problem on my Element. I know, I know, it's not a Jeep but I think they are similar on some level as far as computer control module operation is concerned. In my case I had a tailgate switch(one of two) that was not closing. It did not turn on the dome light or the indicator light. Battery charge would last about 1 week (I rotate vehicles). Found out that the open latch switch was keeping a body control module in an "awake" state and, as a result, was drawing a higher than normal amount of amperage. There were no obvious indication of the switch being open.
I believe (and I could be wrong) that the Jeep CanBus operates in a similar manner. It essentially goes to "sleep" after certain conditions and time are met and then the amperage draw drops to a normal level. I believe there are measurable specs for normal amperage draw. HTH...
"It's not the critic who counts..." T. Roosevelt
MicroMark is offline
post #7 of 7 Old 03-11-2019, 06:47 PM
That enjoyable world of CAN data transmissions over a CAN network !
Isn't it a grand idea and concept ,saving so much copper and resources! Ugh ....
You know that the uninformed sometimes refer to CAN as 'synchronous'. In reality, the term 'synchronous' is kinda misleading 'cause CAN data is transmitted without any form of time/clock signals & in an asynchronous format...
but it'll SURE screw stuff up real good and should be killed with 🔥
(lots of resources online can explain all the 0s & 1s involved if ya use yer Google-Fu
Similar Threads
Dead Battery... WTF? rabidranger JK General Discussion 60 08-15-2013 11:03 AM
Dead battery azrockzuk Electrical & Lighting Tech Dept. 8 06-26-2013 07:13 PM
Dead Battery deker9 JK General Discussion 7 02-29-2012 03:55 PM
dead battery caused jeep to run crazy?? vwang Electrical & Lighting Tech Dept. 7 01-31-2012 09:48 PM
Dead battery NYJKGUY Electrical & Lighting Tech Dept. 22 01-13-2010 10:17 AM
