2017 JKU Feeding a Wire Through Firewall? - JKowners.com : Jeep Wrangler JK Forum
 2Likes
  • 1 Post By ravencr
  • 1 Post By ravencr
post #1 of 7 Old 01-02-2019, 10:35 AM Thread Starter
Hey guys,
I'm wiring up a Rigid Industries 20" light bar to the front bumper, and I was wondering where the easiest place to come through the firewall is. The switch will most likely be on the driver's side somewhere within easy reach. Thanks for the help,
Chris
ravencr is offline
post #2 of 7 Old 01-02-2019, 11:12 AM
This should work for yours. Should be the same on the drivers side.
post #3 of 7 Old 01-02-2019, 06:48 PM Thread Starter
Awesome...thanks for sharing. I'm hoping there's one like that on the driver's side too.
Chris
ravencr is offline
post #4 of 7 Old 01-03-2019, 07:15 AM Thread Starter
I got the light bar wired up to the Rigid switch using their harness last night. The light output is pretty impressive for only a 20" bar.
Chris
ravencr is offline
post #5 of 7 Old 01-03-2019, 08:44 AM
Was that hole there in the firewall?
post #6 of 7 Old 01-03-2019, 08:51 AM Thread Starter
Yep, I went through it on the driver's side under that side panel. It worked perfect. I put the switch just below the AC vent. The light on the switch is annoying bright, so I'll remove that from the switch for sure.
Chris
ravencr is offline
post #7 of 7 Old 01-04-2019, 04:49 AM
aqualungs's Avatar
The JK has two easy access holes... that sounds bad.
aqualungs is offline
