Speaker Wire Colors On Non-Inifinity System - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 10-01-2010, 07:04 PM Thread Starter
allibaster's Avatar
I'm planning on installing a line-out converter tomorrow and need to know the speaker wire colors for the install on the front right and left. Does anyone have this information available for a non-infinity system?
I'm in a '10 2-door if that matters at all.
Thank you.
'13 JKU 10th Anniversary
allibaster is offline
post #2 of 3 Old 10-01-2010, 07:09 PM Thread Starter
allibaster's Avatar
Nevermind. I found it:
This info is for a 2010 2 door with the standard audio system. Other JK models may or may not match.
Front Left:
Gray/Violet + (Green)
Gray/Yellow - (Red)
6.5 inch round speaker, 4 inch maximum depth
Front Right:
Dark Green/Violet + (Green)
Dark Green/Yellow - (Red)
(Colors in parentheses are for the factory speaker pod internal wiring.)
Rear Left:
Black/White +
Dark Green -
6.5 inch round speaker, 3.5 inch maximum depth
Rear Right:
Light Blue +
Light Green -
The factory head unit is woefully underpowered, so don't be surprised to get a fair amount of bass distortion when you use a set of decent aftermarket speakers. It cannot provide adequate wattage to drive aftermarket speakers accurately. I had to turn my bass settings down to -3 to eliminate the distortion. An aftermarket head unit or amp will clear it up.
post #3 of 3 Old 11-07-2010, 07:14 AM
mikeyfl's Avatar
where did you find it at?
i will be installing a sound processor on my '08 and im just gathering all my info.
mikeyfl is offline
