Pico Solder Seal Connectors - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 09-30-2010, 12:04 PM Thread Starter
TrailDuty.com
PhilD's Avatar
Anyone who's installed ORO LiteDOTs will be familiar with these, Pico Solder Seal Connectors. They are not cheap, but allow for quick and easy solder joints without messing around with soldering iron, etc.
They are a heat shrink connector, but unlike the crimp type they have a ring of solder inside them. Simply twist a couple of wires together, slide over the connector, then hit it with a butane torch, as it heats up the solder melts and creates a soldered joint, at the same time the connector shrinks down making a waterproof seal.
I've used them for a while now and really like how easy they are to use and how well they work.
You can get them at plenty of places online in different sizes:
http://www.qualitydist.net/pisoseheshbu.html
PhilD is offline
post #2 of 3 Old 09-30-2010, 12:34 PM
hidX's Avatar
Those are awesome Phil... thanks for pointing them out.
Dave Dorsen [847-410-3750]
*Dealer inquiries welcome*
hidX is offline
post #3 of 3 Old 10-02-2010, 11:22 AM
Hemo's Avatar
Send a message via AIM to Hemo
Phil,
THANKS. I have been going crazy trying to find out what those were called. I installed 10 ORO liteSPOTs and they came with them. They were awesome. So incredibly easy. I've been trying to figure out what they were called so I could buy more. You're a lifesaver.
2008 Rubi Unltd RR Roll Cage - Limb Risers - Evap Skid - Diff Covers PolyPerf HD Ball Joints Reid Hi Steer Knuckles RK 3.5" Triple Threat PRO Longarm Rebel F & R Coil Overs sPod Mini Shrockworks Rock Sliders - Rear Bumper w/ Tire Swing Xenon Flat Flares ORO Onboard Air BD Dual Battery 5.13 Gears 35" BFG KM2s Warn VR12000 Winch Safari Straps Everything Tuffy Security Drawer
Hemo is offline
