esp light and no odometer - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 09-29-2010, 05:21 PM Thread Starter
ok so I have the esp/bas light is on, my odometer or nothing reads in there but seems to drive fine and everything else works?? I checked fuses...So now what> its on a 2008 jeep unlimitted x
frito is offline
post #2 of 17 Old 09-29-2010, 06:28 PM
Slow and Low
Co4Lo's Avatar
INTERESTING!
This is exactly what happens when ALL 4 ABS sensors are unplugged.
Since your speedo/odo will still work with at least one (any one) sensor connected, this would indicate that your problem is more centralized. Like a computer/fuse issue.
Check your ABS System fuse.
Let me know, as this could help me in something I am researching.
Co4Lo is offline
post #3 of 17 Old 09-29-2010, 06:59 PM Thread Starter
the abs light is on as of today, i checked the sensors they look fine, but not sure , if pcm was bad , or cluster bad, just wondered where to start
frito is offline
post #4 of 17 Old 09-29-2010, 07:26 PM
Slow and Low
Co4Lo's Avatar
Aren't you under warranty?
Co4Lo is offline
post #5 of 17 Old 09-29-2010, 07:59 PM Thread Starter
im at 48000 miles
frito is offline
post #6 of 17 Old 09-29-2010, 08:14 PM
block's Avatar
hmm interesting.. that happened to me once when i enter the wrong tire size with a programmer.. drove fine.. just no speedometer or mileage..everything went back to normal when i enter the correct tire size.... did you use any kind of programmer or anything,,,im guessing a computer issue.
block is offline
post #7 of 17 Old 09-29-2010, 09:05 PM Thread Starter
i bought as a repo so who knows if it had or has a programmer?
frito is offline
post #8 of 17 Old 09-29-2010, 10:02 PM
Slow and Low
Co4Lo's Avatar
Is it lifted? Geared? Tires?
Co4Lo is offline
post #9 of 17 Old 09-30-2010, 05:25 AM
neoxxis's Avatar
Disconnect the battery for 10 minutes and plug it back.
Many electronic problems go away after a battery/computer reset...
neoxxis is offline
post #10 of 17 Old 09-30-2010, 07:22 AM Thread Starter
no gears, but it does have like a 2.5 lift and 35,s, i tried unplugging the battery over night that didnt change anything
frito is offline
post #11 of 17 Old 09-30-2010, 10:52 AM
I would take it to the dealership and see if they can flash the computer for your.. Basically reset it and see if that fixes the issue..
Vote - Bacon for 2012!!!
benmar2000 is offline
post #12 of 17 Old 10-01-2010, 07:05 AM Thread Starter
well today, the abs and esp lights go off, then later my speedo quit working,tach still works, and when you come to a stop fuel gauge goes to e, then raises back up? think its the cluster??
frito is offline
post #13 of 17 Old 10-01-2010, 08:23 AM
Slow and Low
Co4Lo's Avatar
I think your Jeep has been under water.
Co4Lo is offline
post #14 of 17 Old 10-01-2010, 12:59 PM Thread Starter
so what does that mean? what do i need to change or do> replace the pcm and speedo? doesnt seem to been wet, but you never know
frito is offline
post #15 of 17 Old 10-01-2010, 05:17 PM
Slow and Low
Co4Lo's Avatar
PM Replied.
Co4Lo is offline
post #16 of 17 Old 10-02-2010, 11:13 AM
Hemo's Avatar
Send a message via AIM to Hemo
I ran into this problem about 2 months ago when I installed a dual battery kit in my 08 Rubi Unlimited. It turned out to be something simple. I discovered that a fairly major connector had come loose. It ran along side the battery towards the TPIM and was located between the battery-TPIM and the engine. Once I plugged the connectors back together everything worked great.
2008 Rubi Unltd RR Roll Cage - Limb Risers - Evap Skid - Diff Covers PolyPerf HD Ball Joints Reid Hi Steer Knuckles RK 3.5" Triple Threat PRO Longarm Rebel F & R Coil Overs sPod Mini Shrockworks Rock Sliders - Rear Bumper w/ Tire Swing Xenon Flat Flares ORO Onboard Air BD Dual Battery 5.13 Gears 35" BFG KM2s Warn VR12000 Winch Safari Straps Everything Tuffy Security Drawer
Hemo is offline
post #17 of 17 Old 11-29-2014, 08:26 PM
Joneszj's Avatar
did anyone ever come up with a solution to this problem?
I recently swapped engines into my JK and am having this issue. I am kind of assuming at this point that it is an abs issue or possible a wheel speed sensor or something similar but i don't want to deal with a stealership to figure it out.
I have almost all the lights lit up on my dash, the odometer isn't working, the speedometer isn't working, and the jeep loses revs as you are cruising along. it'll blip the throttle on its own and get you back to speed.
Thoughts? Help?
1972 Commando on Tons & 40s
Joneszj is offline
