Aux light switch indicator light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 09-17-2010, 01:35 PM Thread Starter
GIjeeper's Avatar
Ok, I tried the search function but I didn't see anything relavent to my question.
I just installed my Aux windshield lights and everything works except the switch indicator light. It's a radio shack 3 prong switch with a small led that is supposed to come on when the lights are on. I tried the switch that came with the lights and it doesn't light up either.
Any ideas?
2005 Wrangler Rubicon
2010 Wrangler Unlimited Rubicon
GIjeeper is offline
post #2 of 5 Old 09-17-2010, 02:44 PM
venom's Avatar
the switch has 3 terminals, 1 is ground, the other supply and the 3rd is output
If you are sure your ground is good and on the correct terminal then try swapping your supply and output wires.
The switch will turn the lights on and off regardless if you have the supply and output wires on the correct terminals, but the indicator light won't work.
Originally Posted by My Wife
venom is offline
post #3 of 5 Old 09-26-2010, 10:36 AM
m(a)ce's Avatar
mini-hijack... based on this can I just cut the on/off switch that came with my IPF 968s & wire up to a to another switch (say a rocker)?
m(a)ce is offline
post #4 of 5 Old 09-27-2010, 08:41 AM
Sure. A switch is still a switch by any name.
"The Green Monster"
2007 2 Door X Jeep Green with Freedom Top
16" Painted Aluminum Mopar Wheels
Grab Bar Mod on front bumper
130w KC Daylighter Driving Beams on grab bar
130w KC Daylighter Long Range Beams
on
Smittybuilt Windshield Brackets
Rock Light Mod
Reverse Light Mod
Mood Light Mod
JK-Ford is offline
post #5 of 5 Old 09-28-2010, 07:28 PM
m(a)ce's Avatar
thx just wanted to check before snipping
m(a)ce is offline
