2007 JKUR Rear lighting issue - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 11-07-2017, 07:15 AM Thread Starter
Rivesracing's Avatar
Question 2007 JKUR Rear lighting issue
I have searched several threads that start with the title "Rear lighting issue" but none that ever actually found the solution. I noticed the battery dying twice in a two week period, not a DD, so it might sit a week or two between nice days. The right rear turn signal quits, check bulbs and swap to the other side all bulbs are good. blow it off as we are going on a 10 day trip off roading with it and T/S are overrated on the trail anyway. Day two on the trip lose left rear turn signal and come to find out the brake lights are not functioning either. Check all connections, clean everything up, remove the trailer harness from the equation, still only have running lights. Check continuity from module to each light, no problem there, when I did a voltage check, it read 10.9 on each circuit with everything OFF. Seems odd to me that there is voltage on the circuit with keys on the seat. anyone else have this issue and found a solution? Thoughts?
Rivesracing is offline
