Seat problems - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 08-13-2017, 10:26 AM Thread Starter
Seat problems
Just swapped the seats in my 2012 jku with leather from s 2016 jku. The harness is different. Seat belt buzzer goes off and air bag light is on. How can I disable the seat belt buzzer since the light is on ? Can the airbag be disabled since I'm gonna be rock crawling with it ? I'm out of ideas
Scmike is offline
post #2 of 3 Old 08-13-2017, 01:17 PM
I would probably look at converting the harness type attachment to the newer if possible. Cant you buy the right end off an '16 seat and use a wiring diagram to pin it out correctly ,is it possible?
Otherwise, I am recalling some sort of wire located down around the rear cup holder area that controls the seatbelt alert. I cant help you with disabling of an airbag; probably not a good idea even if it is "just for rock-crawling"
post #3 of 3 Old 08-13-2017, 06:29 PM Thread Starter
I had an idea earlier. Take both sets of seats to my upholstery guy and let him swap the covers and padding . What do ya think ? Then everything would plug in correctly.
Scmike is offline
