Possible clock spring - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 07-30-2017, 11:32 PM Thread Starter
So just like the many others, I mistakenly left my top down during a torrential downpour. Now a week later my jeep is going haywire. Windshield wipers, windshield wiper fluid pump, the horn, and lights instantly kick on the second any electrical power turns on and will not turn off till I disconnect battery power. Neither the heat nor air conditioning turns on anymore. I pulled the circuits for the horn and windshield wipers knowing it would only be a temporary fix. From everyone else's posts I've decided it's my clock spring having issues. Is there anyway to test this before o start ripping my steering column apart? Could it maybe be my circuit board?
MagsNHannah is offline
post #2 of 3 Old 07-31-2017, 03:50 AM
KJV
KJV's Avatar
Just went through a similar issue. Pull the battery cables for a few hours. Pull a part the instrument cluster/gauges and disconnect the cluster. Blow out all connections. I also disconnected and reseated all PCM connections. Give this a try first.
2010 JKU. 3.5 RK Flex, 37" Nitto Trail Grappler MT, Method 105's. Poly Drag link, Fusion 4x4 Tie Rod, DIY Hydro Assist, Ultimate Dana 44 Front, Rubi 44 Rear. Ten Factory Chromoly Axles, EVO RockStar Skids 5.13's, VKS Shorty V2 with Warn HS9500i, EVO rear D-ring mounts, VKS Prerunner Sliders, Synergy Cage
KJV is offline
post #3 of 3 Old 09-28-2019, 11:17 PM
MOKOS's Avatar
Were you able to resolve this? What was the solution? Mine is having similar issues.
_____________________________
110"WB 07 2dr JK
MOKOS is offline
