Camshaft sensor replacement 2013 JK - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 07-26-2017, 09:52 AM Thread Starter
Hey everyone, just seeing what kind of answers I can get on here since I've seen quite a few varying ones. I am needing to replace my camshaft positioning sensor on my jk. It keeps throwing a p0349 code telling me that it's the drivers side that needs replacement. With this, it is causing it to go into limp mode unfortunately. Now, I've heard that only the dealership can do it cause they need to recalibrate the sensor. I've heard that if you replace it yourself you need to disconnect the battery and let it sit all night after replacement. Then I've heard that it's just a simple swap out and nothing more. If anyone has experience with this and knows the right route, I'd really appreciate the info
Josh Edstedt is offline
post #2 of 2 Old 12-26-2018, 07:09 AM
its an easy swap out, part is only about $25.00, but i did replace it and unhooked the battery, and it didnt fix the problem, its a commaon problem with the pentistar, but so far searching all of the forums I have not found a definite fix. still looking
SteelBlueJK is offline
