Head Scratching P0AC1, P0480, and Sway Bar Awesomeness - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 07-13-2017, 04:02 PM Thread Starter
chidychi's Avatar
Exclamation Head Scratching P0AC1, P0480, and Sway Bar Awesomeness
The rig:
2012 4door rubi.
The Background :
So my Sway Bar Disconnect circuit board got all corroded and the sway bar light started flashing about a month ago. At this point I just knew the light was flashing.
I took her wheeling last weekend, and went into some water that completely submerged the disconnect.
After that the dash went a little nuts, flashing all kinds of awesome. So I knew I had an electrical issue.
After a while the prob went away. I checked codes, and only had "Network" codes, and successfully cleared them.
Checked grounds etc, and drove for a while (hours) no problem.
Then the problem returned, and the jeep wouldn't start anymore.
So I lurked the internet and figured out it was the sway bar.
So I tried disconnecting the wiring harness from the disconnect, and the Jeep was able to start and all the electrical weirdness went away.
The Problem:
After all this, I am getting the following codes:
P0480 - Cooling Fan Control Circuit 1.
P0AC1 - Hybrid Battery Pack Current Circuit Sensor "A" Circuit Low
+ several "Network" codes.
When I clear the codes they come right back.
P0AC1 is regarding a Hybrid vehicle from what I can understand....guess only the 12's got this.
I looked at the 60Amp fuse... it looks fine.
The fan comes on, but I can't tell if the fan is high or low; and am unsure how to force it.
The fan is very easy to turn by hand, and keeps turning if I give it a little spin.
I tried removing the sway bar circuit board and cleaning it and reinstalling. I think it is beyond use. The sway light is still flashing, and I can live with that.
I'm about to go on a huge trip covering thousands of miles driving in some desolate areas..... So I'm a little freaked out about this. Leave Saturday morning.
Is is possible that the fan error is just a result of the sway circuit screwing with the CAN?
Will my hybrid battery ever come on and save me gas????
chidychi is offline
post #2 of 9 Old 07-13-2017, 06:22 PM
if you have an aev pro cal you can disable the electronic swaybar and it kills the flashing light.
Jadmt is offline
post #3 of 9 Old 07-13-2017, 08:06 PM
".. went a little nuts,flashing all kinds of awesome."
hehe
welcome to jkowners
post #4 of 9 Old 07-14-2017, 10:05 AM
coilrod's Avatar
This. And procal is not pricey. Had same issue. Procal eliminated it.
coilrod is offline
post #5 of 9 Old 07-14-2017, 10:24 AM Thread Starter
chidychi's Avatar
ya definitely going to do that, but am more worried about the fan at this point. I just can't figure out why it's throwing those codes
chidychi is offline
post #6 of 9 Old 07-14-2017, 10:59 AM Thread Starter
chidychi's Avatar
So according to this topic, https://www.jkowners.com/forum/stock-.../270930?page=2 , it sounds as if the 2012+ jk may not even have a high speed? I am having trouble finding the high speed fan relay..... Does it even exist on the 2012+ jk?
chidychi is offline
post #7 of 9 Old 07-14-2017, 03:14 PM
It seems the 2012 and newer fans are brushless and outrunner design, with the Jeeps computer controlling fan speed. My 2011 3.8 has a 2 Spearhead fan, and it is controlled by a resister.
Mjp83 is offline
post #8 of 9 Old 07-14-2017, 04:04 PM
all due respect; just adding that the '07-'11 3.8l jk/jku have a voltage divider ( step down) resistor that is how the speeds are attained for hi,low. That funky ,ceramic connector you plug the fan into ...it has a funky name..there's a thread where either the JSS guy or RPMExtreme guy talks about it on here but I'll have to search for it. Anyway, just chippin'-in to help with the information share
post #9 of 9 Old 07-14-2017, 09:20 PM Thread Starter
chidychi's Avatar
Well.....All the codes have disappeared.
I disconnected the battery for about 10 minutes and the codes never came back after that.
I know... I know.... but I've used Torque before with that adaptor to clear codes and I've never had a problem.
I leave tomorrow on a crazy long road trip... so we'll see if the codes come back.
Appreciate all the help....glad the codes are gone.
Can't wait to see what MPG I get now that the "Hybrid Battery" is working properly again!!!!
chidychi is offline
