Raxiom Replacement Fog Light Install Questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 07-13-2017, 02:01 PM Thread Starter
Mlord's Avatar
I purchased a pair of Raxiom LED fog lights to match the headlights. I knew that there was supposed to be some splicing for these but have run across a few concerns/questions.
I searched the site for Raxiom specific fog light install and went through about 15pages worth of random shit.
The Raxiom fogs come with a set of pigtails and their direction are to cut off the stock plug and wire the pig tails into the stock harness and thats that..
So my questions;
-If I simply do just this, I've heard of people having flickering issues that seem to be common with replacement LED fogs. I purchased an Xprite anti-flicker harness that is compatible with the H10 fitting and it has plugs on each end of the harness.
-I also ordered some butt-connectors to properly pair the wiring together.
-Would that harness be all I need to stop flickering? And would I just cut one of the plugs off the flicker harness and wire the Raxiom fogs to it, and then plug the anti-flicker harness into the stock foglight harness?
Im trying to have these be able to operate on the stock foglight switch as well. Any input would be appreciated. Im not an expert at wiring at all and have been searching and reading as much as possible.
2017 Jeep Wrangler Unlimited Sport
-ZoneOffroad 3" lift
-Front & Rear Adjustable Trackbars
-braided brake lines
-LED headlights & Taillights
-Custom white leather w/ black stitch seats
-16x8 Pro Comp Series 31 Wheels
-Yokohama Geolander M/T 315/75/16
____________________
Late 2018 build: Scrap current lift.. Go expensive AF.
-Fully comprehensive lift kit
-air lockers
-re-gear
-heavy duty Front & Rear driveshafts
-heavy duty ball joints
Mlord is offline
