Amp wiring questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 08-31-2010, 09:06 AM Thread Starter
thaduke2003's Avatar
So I'm replacing my OEM speakers with Poly db's tomorrow. I have a Pioneer deck. I'm looking into adding a marine-grade amp, and had some questions.
First up, where are folks running their power wires through the firewall?
Next up, for my fellow mud hunters- where are you mounting your amp? Was thinking of a podium or stand, so it's off the floor, so I can still wash out the back with no worries.
Ideas welcome! Thanks- Mark W.
thaduke2003 is offline
post #2 of 5 Old 08-31-2010, 10:11 AM
The Joker's Avatar
I mounted my amp upside down on the bottom of passenger seat. It's held on by some insanely strong zipties. I put the controls facing the rear so I can easily adjust it. It's about 4 inches off the floor so water isn't an issue. A friend of mine did the same thing and gave me the idea. It works out great.
Hope that helps.
The Joker is offline
post #3 of 5 Old 08-31-2010, 05:32 PM Thread Starter
Hmm- only problem is, I'm planning on going to a suspension seat over there- might cause issues- I'll look into it. Solid idea, just not sure if it'd interfere- Mark W.
post #4 of 5 Old 09-01-2010, 03:59 AM
ynkedad's Avatar
I have two amps. One mounted under each front seat. I ran the wires thru the firewall (driver side).
If you pop the hood and look towards the right of the brake reservoir, you'll see a rubber grommet.
I uses a screwdriver w/some tape to push the wires thru.
I Freakin' Love My JEEP!! Hey, you in the Hummer..
I Love and Miss You Brodude..RIP.
ynkedad is offline
post #5 of 5 Old 09-01-2010, 07:02 AM
jerryn's Avatar
I ran a wire through the firewall grommet near brake resevoir
Piece of cake. my amplifier is located below the steering column behind the dash. I tapped the accessory lug on the fusebox and ran the cable through the driver's side firewall grommet. I just punctured a hole with my jacknife. I removed the grommet before I made the hole.
jerryn is offline
