Air Bag Light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 08-30-2010, 07:01 PM Thread Starter
Air Bag Light
Went wheeling yesterday and all was well. Heading out of the park my air bag light on the dash would light up and chime ( the same chime as the low fuel warning.) It keeps going on and off and the damn chime is driving me nuts.
This morning I figured I would disconect the battery and see if that would do the trick. What I found under the hood was a cracked battery. So I replaced it with a Sears Platinum series hoping that would do it. No Luck.
I have checked the connections under both seats and all looks to be in order. Does any one have any idea what it could be ???? Is there a sensor or something mounted on the frame or body that may have been knocked loose ????
07 2 Dr White Rubi, 6spd
Linexed tub
EVO Rear Bumper Fascia
Poison Spyder Boby Mounted Tire Carrier
Matercraft grab handles
M.O.R.E. 1" BL
Shrockworks midwidth w/ winch hoop / Linexed
Warn 9.5TI / Spidertrax fairlead / Viking trail line
Marathon Seat covers
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
3.5" Rock Krawler X Factor
Coil Overs Front/rear
12" rear stretch
River Raider stretch corners
Smittybilt XRC front enders
07JKRUBI is offline
post #2 of 12 Old 09-02-2010, 04:09 PM Thread Starter
BTT...
I have done some reading and have come the conclusion that it my be the damn clock spring....Is there a way to test it and how hard would this be as a DIY fix????
Linexed tub
M.O.R.E. 1" BL
PC 8179's 15x10
Toyo MT 37x14.50x15
Shrockworks sliders
EVO C2 Gussets
12" rear stretch
07JKRUBI is offline
post #3 of 12 Old 09-02-2010, 04:25 PM
hidX's Avatar
Sounds like it is most definitely the clock spring. Mine has been this way for a couple of months. Drives me crazy, but I keep procrastinating the install... There is some decent info on here if you keep searching around.
Dave Dorsen [847-410-3750]
*Dealer inquiries welcome*
hidX is offline
post #4 of 12 Old 09-15-2010, 12:33 PM
4x4LOYR's Avatar
My clock spring went bad as well. I just plugged the fuses and the stupid chiming went away. (Of course, I still have the dash light, but that I can live with).
Your Southern California wheelin' Attorney
4x4LOYR is offline
post #5 of 12 Old 09-20-2010, 04:11 PM
ruicondevil07's Avatar
Yep clock spring, mines been like that about a year now. Mine only chimes right after startup and I just ignore it. Seatbelt light is still on though. Maybe one day I will get it fixed. So for now its just the finger to people. yeah horn doesn't work either.
ruicondevil07 is offline
post #6 of 12 Old 10-13-2010, 06:02 PM
Mr. T's Avatar
Mine just started doing this recently too. It only really comes on after about 40 minutes of driving. Does the on/chime and then off for a while. Really random and doesn't happen often. Any word on this clockspring replacement? And wtf is it?
Jersey
Crew
JK retired Wednesday, March 21st, 2012.
07 X 6spd • Clayton 3.5 • OME LT • ORE Gussets/Sleeves • RCV Shafts • JKS Discos & Track • AEV Snorkel • FLW Rear Bumper • RRF Front• PSC Sliders • RROR Skids • Poly P. Ball Joints• Wood's Shafts• Yukon Gears • Maxxis Kreepy Krawlers • Superwinch epi9• Safari Straps
Mr. T is offline
post #7 of 12 Old 10-19-2010, 04:59 PM
Ken Jong Il's Avatar
Originally Posted by 07JKRUBI View Post
BTT...
mine started doing it when I replaced my seats. Whats the clock spring?
07 Rescue Green Unlimited
Upcoming projects - Much needed TLC
Ken Jong Il is offline
post #8 of 12 Old 10-19-2010, 05:12 PM
tehiv's Avatar
The clock spring allows your steering wheel to turn without binding all the wiring in there. The part costs just over $200. Out of warranty, it'll run you about $500 to get a dealer to replace it.
Mine has been dinging for over a year. It's very intermittent. Sometimes I'll go weeks without a ding, then it'll do it 5 times in a 30 minute drive.
tehiv
'14 Copperhead JKUR
'14 White WK2 Overland
formerly: 98 TJ | 97 XJ | 05 TJ | 01 WJ | 07 JKU
tehiv is offline
post #9 of 12 Old 10-19-2010, 05:24 PM
jeepnick's Avatar
Picked one up for 176 shipped from mopatdiscountparts.com
We're Installing tomorrow will post up with how goes
jeepnick is offline
post #10 of 12 Old 10-21-2010, 01:43 PM
kenallwine's Avatar
Any progress on this? I would like to know a part number if anyone has one.
Ken Allwine
2007 JK Unlimited Sahara
kenallwine is offline
post #11 of 12 Old 10-21-2010, 03:26 PM
jeepnick's Avatar
I google it
For the part number
Install went smoothly
Nice to have my horn/cruise back
And the traction lights off
jeepnick is offline
post #12 of 12 Old 10-21-2010, 06:30 PM
Jeep School's Avatar
If the Airbag light goes on and off, like every time you turn a corner, then it is your clockspring. If the A/B light goes on and stays on, it still COULD be the clockspring, but about 1 in 50 times, it is a bonafide Airbag problem.
Nena Barlow
Jeep School is offline
