How many taps into power outlet - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 08-26-2010, 09:50 AM Thread Starter
WranglerPike's Avatar
I see alot of people saying they take power from the + of power outlet, for relays and such. How many different times can you tap into it? I have my radar detector hardwired to it, about to have it trigger a relay for my lights this weekend hopefully, then I want to install a second outlet in the rear of the Jeep either back seat or cargo area. None will have major draw. The outlet up front will be Ipod or cel phone charging, rear seat for DVD player for the kid, and the rear for a small compressor we use to air up tubes or other beach floaties. To me this seems like a lot to run off there but any suggestions? If it's a major undertaking, I'll just deal with the power outlet being in the front.
WT
2009 Red Rock Unlimited
Helo 842 Wheels, homebrew lite bar, congo cage, midchop bumper, daystar spacers
WranglerPike is offline
post #2 of 3 Old 08-26-2010, 11:14 AM
ronjenx's Avatar
WT
You would be better off to find a switched source from the fuse box and run your stuff from that. You may even find an empty socket you could put a fuse in. It would be dedicated to your accessories, then.
ronjenx is online now
post #3 of 3 Old 08-26-2010, 11:34 AM
bluerubicon08's Avatar
I bought a power block from the local Autogroan store, ran a primary wire from the positive terminal of the battery through the dashboard to it with a 30amp fuse attached. That is what I have used fopr my CB, Interior LED lights, and Windshield lights. There are numerous write-ups on this type of set up. If you pull off the side plastic panel on the dashboard onn the passenger side, there is a hole there that is filled with foam behind it. Just run a stiff wire through it, like a coathanger, then use that to pull your primary wire through.
If you're gonna be fucking weird, own it.
~SoCo
______
bluerubicon08 is offline
