AC problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 08-20-2010, 11:39 AM Thread Starter
wastedyouth02's Avatar
Send a message via AIM to wastedyouth02
AC problem
SO on my way to vegas for last years SEMA my AC magically cut out and hasnt worked since, i figure its about time i get around to fixing it. The AC light on the switch panel comes on when you press the button but the clutch does not engage. As far as i can tell no fuse is blown (ive used a meter to check them) and the system is fully charged. At the connector right before the wires go down to the clutch im getting 13volts, what should be next to check.
wastedyouth02 is offline
post #2 of 8 Old 08-26-2010, 07:28 AM
ronjenx's Avatar
Did you check if any codes were set?
Here is a list of possible causes.
Since you are getting power to the harness for the clutch, #3 looks most likely.
1. No refrigerant in the refrigerant system.
2. Open fuse.
Check the fuse in the junction block. Repair the shorted circuit or component and replace the fuse as required.
3. Inoperative A/C compressor clutch field coil.
A/C Clutch Coil Resistance
4.2 ± 0.2 ohms
When measured across coil lead connector @ 25° C (77° F)
4. Improperly installed or inoperative A/C pressure transducer.
5. Improperly installed or inoperative Evaporator Temperature Sensor.
6. Inoperative A/C-heater control, totally integrated power module (TIPM) or PCM/ECM.
ronjenx is offline
post #3 of 8 Old 08-26-2010, 09:31 AM
Do you have refrigerant?
post #4 of 8 Old 08-29-2010, 07:46 PM Thread Starter
I have tried re-charging the system to no avail.
By junction block your refering the the one between the airbox and battery correct? or is there another one im missing
im getting 4.4 ohms across the coil
Today as im playing with it again, i am no longer geting power to the clutch harness. Im printing out the diagrams now to go back out and see wtf is goin on. Are these systems conrolled on the ground side as in the ecm grounds the circuit to turn it on?
post #5 of 8 Old 08-29-2010, 10:17 PM Thread Starter
So i definitely do not have voltage to the clutch, manually applying power the clutch does engage and the ac blows nice and cold with in about 5 seconds. Im going to check the transducer for signal voltage tomorrow which should tell me a lot.
post #6 of 8 Old 08-31-2010, 03:19 PM Thread Starter
So i have 5volts going into the transducer but my meter's probes wont fit into the plug to back probe it, Will a scan tool i cna borrow from the vatozone tell me voltages on that. Also does the turn the ignition 3 times thing pull any and all codes available or just P codes?
post #7 of 8 Old 08-31-2010, 03:43 PM
I would be very careful putting power to anything on the JK....
I know a jeep tech that had a JK come in with a bad TIPM because some mechanic put 12v directly to the horn while the factory harness was still connected...
no jeep here...
Racer83l is offline
post #8 of 8 Old 09-01-2010, 08:55 PM
bfj aka tambil's Avatar
If you don't have voltage at the clutch..
First check the fuse, then the relay, if no power at the relay then check the control unit. The one you turn the ac on in the cabin. Does the control unit respond to other controls? Like the ac button turns on and off, the vent selector works, etc.
Its obviously electrical and not actually the mechanical ac itself. You can also use a paperclip to jump the low pressure switch to see if that makes the ac engage. BUT that doesn't sound like the problem based on what you have said so far.
Good luck.
Proud to be an American
Shamed of our government
Native Floridian = MUD
bfj aka tambil is offline
