3 way switch and 2 pair of lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-17-2010, 12:56 PM Thread Starter
WranglerPike's Avatar
I have a pair of driving lights in the front and a pair of back up, trail lights in the back of the JK. I have a 3 position on-off-on switch. I will never run both sets of lights at the same time. Can I wire them to the 3 way switch with a relay? Trying to not have a lot of switches and holes in the dash. They are 55W lights. If it is possible anyone have a diagram I can follow?
2009 Red Rock Unlimited
Helo 842 Wheels, homebrew lite bar, congo cage, midchop bumper, daystar spacers
WranglerPike is offline
post #2 of 6 Old 08-17-2010, 02:38 PM
07unlimitedx's Avatar
It is best to use a relay... I can't see why you wouldn't be able to run on/off/on switch. I'm at work and can't get you a pic, but maybe someone can chime in and get you one.
You will only be able to run one or the other with this switch.
Steve
07unlimitedx is offline
post #3 of 6 Old 08-17-2010, 04:32 PM Thread Starter
Correct. I will run one or the other. I think it will work, but wanted some electric gurus to chime in before I burn my Jeep down
post #4 of 6 Old 08-22-2010, 02:07 PM
Cool I would use two relays.
From battery, to a fuse holder (20 Amp), then to the common (terminal # 30) of one relay, then jumper over to common of the second relay. (16 to 18 ga. wire should do) I have mine tucked behind the glove box.
Take a switched 12 volt source (most tap into + of power outlet) to the common of the three way switch (middle??). Then from each switched leg of your three way, to coil + (86) of each relay. This will be the signal to tell the relay when to turn on/change state.
Then connect your front lights + to N.O. (87) of one relay, then do the same for the back lights to the second relay.
Coil - (85) of both relays, as well as - to both sets of lights should go to ground (or bat -).
hope this helps.
scott1 is offline
post #5 of 6 Old 08-23-2010, 04:10 PM Thread Starter
That is awesome. Appreciate it. Had reread it a few times, made my head hurt. That's what I needed. Have to do it this weekend.
post #6 of 6 Old 08-26-2010, 06:46 PM
Glad to help.
You will want to put the ("water-proof") fuse holder as close to the battery as possible, if it grounds out the entire ckt. will be protected.
scott1 is offline
