Rear driver side blinker does not work - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-16-2010, 09:14 PM Thread Starter
My rear driver side blinker does not work at all. The running lights and brake lights work, and all other lights work. The front driver side blinker blinks fast, probably cause the rear one doesnt work at all. I have aftermarket LED lights installed which arent a year old. Dont know where to begin looking for the problem. I did a visual inspection and everything seems to be hooked up still. Any ideas?
Blaggatone is offline
post #2 of 6 Old 08-16-2010, 10:35 PM
RiggerMike's Avatar
With regular, stock lights the situation you describe would mean the driver's side rear bulb was shot. Not sure with the led's...
Current Mods:
  1. Cleghorn tailpipe mod
  2. Cleghorn side step ventilation with Gold Mtn. enhancement
  3. Heartbreak Ridge bumper scuffs
  4. Goler gas tank skid mod
  5. Miscellaneous pin striping
  6. Woods evap cannister relocate (Wow, an intentional mod!)
  7. 2"BB and swapped in stock Rubi coils and shocks (thanks Seth!)
  8. Calico fender realignment and texturing
  9. Calico "explodey the side step" ez removal kit
  10. Stock Rubicon rails courtesy of JackTuttle (Thanks Jack!)
  11. Solid Axle dif covers
RiggerMike is offline
post #3 of 6 Old 08-16-2010, 10:48 PM
HOOLIGAN's Avatar
Since it's not just one LED that is out it makes me think that it is a wiring or a circuit issue. Are you able to remove your left one and plug it into the right side and see if it works? If it does then you've at least narrowed it down to a non-wiring issue.
HOOLIGAN is offline
post #4 of 6 Old 08-17-2010, 05:04 AM
I had this happen and it turned out there was a fuse blown under the hood
BlackRube is offline
post #5 of 6 Old 08-17-2010, 05:41 PM
Mr.RonGilbert's Avatar
Mr.RonGilbert is offline
post #6 of 6 Old 08-17-2010, 05:50 PM
fishinmagician's Avatar
you need blinker fluid
fishinmagician is offline
