Feeling Stupid - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 08-11-2010, 08:32 PM Thread Starter
07unlimitedx's Avatar
Feeling Stupid
Well, I just got my new switch bezel from S-Pod and a BIG THANK YOU TO JOHN for getting it to me so quick.
The problem is, it's been a while since I had to hook everything up in my last jeep that I forget where the ground, lead from the relay and what the 3rd wire would be for?
Anyone help?
Thanks,
Steve
07unlimitedx is offline
post #2 of 6 Old 08-13-2010, 03:23 PM Thread Starter
Carling Switches
Does anyone have any information on how to get this Carling switch hooked up properly? Been trying to get it to work with no success. Please Help.
post #3 of 6 Old 08-13-2010, 06:20 PM
scottrock's Avatar
Sorry if this aint no help but, did you dig around on the manufacturers website?
http://www.carlingtech.com/support/product_search.asp
scottrock is offline
post #4 of 6 Old 08-13-2010, 07:08 PM
Not exactly sure of the pin out, but it shouldn't be that hard to figure out. One is 12v+, one is ground, and the other is to the load. Take a meter and OHM out the pins to figure out which ones are the contacts, and the other will be the ground.
My sig is HUGE in Japan
Jscwerve is offline
post #5 of 6 Old 08-13-2010, 07:58 PM
Terminal #2 is connected from your power source, battery, ignition, etc.
Terminal #3 goes out to your relay.
Terminal #7 is the ground for the light in the switch.
otrattw is offline
post #6 of 6 Old 08-13-2010, 09:38 PM Thread Starter
Thanks to all of you! You all were a big help!
