Antenna mountings - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 08-07-2010, 12:04 PM Thread Starter
Antenna mountings
Made some brackets from aluminum angle iron to fit the 29MHz and VHF antennas. In SA most 4x4 owners use the "old" AM 29Mhz radios, while the trend is now to move to the better 2m VHF band. So many of us got 2 radios and some 3, if you are a HAM ;-)
Have not seen any pics yet on mounting them there, but I think it will work well. The left side mounting can be used for the 29Mhz antenna or my HAM radio antenna (the 1 in the pic)
I put some double sided tape between body and bracket to secure it better and also prevent damaging paint behind it. The fixing screw still makes a good ground contact with body.
Right side - VHF:
Left side - 29 or HAM:
Johan
Cape Town, R.S.A
2007 JK 2.8 Unltd
ZS1JV
JDeV is offline
post #2 of 4 Old 08-08-2010, 05:51 AM
Liquor's Avatar
moved my radio antenna to the tire carrier. next to the 102" whip. works out fine. put a trail rated badge over the hole it left in the right front quarter panel.
Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #3 of 4 Old 08-08-2010, 07:54 AM
chromedome's Avatar
How does the inductive reactance from the AM/FM antenna affect your setup in terms of SWR & radiation pattern?
chromedome is offline
post #4 of 4 Old 09-14-2010, 04:03 AM Thread Starter
I actually remove the FM antenna when using the 2way radios. I don't like the 2 antennas hitting each other when driving - for no other reason then the continues kling, klang, klong noises made by it.
When I don't use the 2way radios, I hook the antennas to the roof gutters to keep them from hitting my garage door when driving in and out. The garage door opens vertically, upwards.
Johan
Cape Town, R.S.A
2007 JK 2.8 Unltd
ZS1JV
JDeV is offline
