stock sub hook up - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 08-02-2010, 09:20 AM Thread Starter
yellowx2rubi's Avatar
Question stock sub hook up
ok well i purchased a infinity mygig sound system and hooked up with with back up camera and still havn't found a good spot for it to go and also i put the loc-pic in there too. I also purchased a stock sub for the rear of the jeep. My jk didn't have it when i purchased it but the wires are there for it and it plugs in great etc. The only problem is that the sub doesn't work. Is there a AMP somewhere or can someone explain what i have to do to get it to work properly. I have basic knowledge and exp. with the jeep. Any ideas with out major electrical cutting and splicing etc. thanks- any help would be appreciated.
yellowx2rubi is offline
post #2 of 11 Old 08-04-2010, 02:10 PM Thread Starter
any help would be great... anyone have any ideas???
post #3 of 11 Old 08-04-2010, 04:50 PM
07unlimitedx's Avatar
I had an 07 that only had the basic stereo... no sub, but had the wire just like yours... I now have a 2010 with the full system, sub etc... what I have noticed is that there is an amp under the stearing column. If you don't have the amp, your sub won't work. Hope this helps.
07unlimitedx is offline
post #4 of 11 Old 08-04-2010, 07:17 PM Thread Starter
any ideas of size of amp needed? is there connectors inside from stereo to amp for amp to connect to sub? so where does the wire from sub to stereo go to? ideas? I am looking... its like a mystery... don't want to take the whole dash apart... again!
thanks
post #5 of 11 Old 08-06-2010, 10:42 AM
I'll take a look today and see what I can see.
post #6 of 11 Old 08-06-2010, 08:55 PM Thread Starter
ok great- thanks for your help. I looked but don't see much. I am just stuck between the stereo connection and the amp to the sub part. can't figure out wires. grrr
post #7 of 11 Old 08-07-2010, 01:15 PM
OnTheRoks's Avatar
amp
Dude, you need an amp. It's plug & play and you can even find upgrade amperage models for reasonable prices. Check Mopar for stock numbers and then start searching the vendors. You'll also get more power to your dash speakers, allowing to upgrade
OnTheRoks is offline
post #8 of 11 Old 08-09-2010, 08:04 AM Thread Starter
yes i know i need a amp. But i opened the spot where they are connected ususally and i didn't see the wires in there but the wire was in the back to connect the factory sub that i purchased for 20 bucks but now just trying to figure out amp and connections. Any idea on size of amp and where the connecting wires go? Thanks
post #9 of 11 Old 08-11-2010, 08:46 PM Thread Starter
what size amp is in a stock jeep for the stock sub?
anyone know what size amp is in the jeep stock for the stock sub to work... i can't find it anywhere... any one know where i can get one or anyone sellling theirs? Thanks
post #10 of 11 Old 08-11-2010, 08:53 PM
I have a stock Infinity amp you could buy off me if you want to PM me.
I have taken the factory connector off and ran wires which I have labelled. I originally was going to install it elsewhere but obtained another amp instead of dealing with the CAN message wakeup and tuning. I had overrode the IC that enables the unit on a CAN wakeup message, but this is easy to undo. I never made it far enough to actually test it on another system, but it definetely powers up and will work for you without having to find the right connector to plug into it, I found the 16 pin connector and pins at work but the 22 pin must be proprietary and I cannot find anywhere.
gign0894 is offline
post #11 of 11 Old 08-11-2010, 09:32 PM
Here's a couple of photos from the back of the amp and a model number.
Here is something else I just found... hope this helps.
http://www.neoxxis.com/jeep/JK07_ste...ing_no-amp.zip
